Built 2.0L FP Red S2 Toxicfab tubular e85 & 93oct results
i don't know if it sucked in air or not, it was just a guess since he has a stock oil pan.
i was told by fp to baffle my oil pan and get a proper catch can ventilation setup though,
and once i did everything they said, i never killed another turbo since then.
looking at the blades on the wheel and all the bits missing. Is there a chance of that crap getting into the motor?
Or dose the intake manifold catch most of it?
For it to actually enter the engine, It would need to travel out of the compressor outlet into the lower intercooler piping, then bust through the intercooler core itself, then work its way past the other side where the upper pipe connects on the endtank. Then finally, travel up the upper pipe and enter the intake manifold.
this failure happened high rpm in 4th gear, so it was most likely due to the shaft speeds. overworking the turbo. we were out to get a high trap mph at the track and pushed the turbo a bit to much. it happens. its certainly not the turbos fault.
the reason we did not get a track result with this car, is because englishtown ran out of tech inspection cards and turned him away.. so he drove 3-4hrs for nothing.. so on the way home they had some fun and that's when it happened.
Black is good because it's bolt on, but expensive and will always be bolt on, and doesn't give much more power than I already had.
HTA3586R is good because it's a nasty turbo and makes retarded power, but requires a new manifold and o2 housing ($1300+).
ATP GTX3582r is nice because it's bolt on now, and I can upgrade the housing to T3 if I ever feel the need.
Not really sure now, all 3 options are over $2k so it is going to happen slowly over winter.
Between me and the previous owner less than 8000 miles? The turbo never saw under 30 psi in my ownership though. I don't blame the turbo for this, we forced it with the grimmspeed to hold as much as it could up top.
1 Post
Holy crap that turbo is nasty! I would be very interested in seeing results from the ATP GTX3582R on your car. Flyin_banana, in the stock appearing turbo thread, had some great results from that turbo this year.
flyin_banana's car is what got me seriously interested in that turbo to be honest. 140 traps are insane. His car is STUPID light compared to mine though. Without me in it it's 3250, which even then is lighter than a normal SSL so I have no idea how since only thing removed is the sub. It's still got the entire full interior, ac etc etc
I'd like to do 9s, full weight, next season. We'll see though, it'll add up and I won't have much track time due to being kicked out for no cage since I refuse to cut up my car.
1 Post
It was a very bad breakage, turbo loss isn't a big deal. I was really bummed when I was unsure of motor condition.
Haha, very true, his car is an estimated 600lbs less than your car. Sounds like you need to spend some time in the weight reduction thread! Put your pig on a diet over the winter! There are plenty of things you can do & still keep full interior, AC, etc...
https://www.evolutionm.net/forums/in...have-done.html
