2.3l 920hp evolution 4 gsr from sigma speed indonesia
Iman's evo 4 street car GSR
Engine
-86mm Mahle F1 series 2.3L piston kit
-Carillo Pro SA Beam Rods
-4G64 100mm stock crankshaft
-AMS Balance eliminator Kit
-ACL "calico coating" race bearing
-Toga Oil pump
-ARP main stud
-ARP fly wheel bolts
-Tomei oil pan baffle
-HKS oil thermostat
-HKS oil Filter
-HKS thermoswitch
-Cosworth head gasket
-A1 head stud
-GSC Lifter
-GSC 274/274 camshaft
-GSC Valve spring retainer kit
-Ferrea Valves
-Supertech Valves seal
-Supertech valves lock
-ATI super damper
-Skunk2 intake manifold
-S90 throttle body 70mm
-HKS camgear
-TODA timing belts
-HKS Twin power kit
-Ultra racing Plug wire
-HKS Sparks plugs
-Full Race T3 Prostreet manifold
-FP HTA 3794R
-Tial 44mm wastegates
-Tial type q blow off
-Custom 3" piping all alumunium all around
-ARC radiator
-Billion hose&fan
-custom FMIC
-Sard fuel rail
-HKS 1000CC injectors
-Dual Bosch 044 fuel pump
-Custom fuel tank and braided line
-PPG Diff tube
-Ralliart all mount
-Ralliart super traction LSD fr&rr
-evo 6,5 TME prop shaft
-ACT extreme clutch kit
-ROTA slip stream with Nitto 555R drag radial
-D2 Drag coilover kit
fully tuned and built by sigma speed indonesia
920 Hp @36psi @dastek 4wd dynamometers
Engine
-Toga Oil pump
-ARP main stud
-HKS oil thermostat
-HKS oil Filter
-HKS thermoswitch
-A1 head stud
-GSC Lifter
-Ferrea Valves
-ATI super damper
-HKS camgear
-TODA timing belts
-HKS Twin power kit
-HKS Sparks plugs
-FP HTA 3794R
-ARC radiator
-Billion hose&fan
-custom FMIC
-Sard fuel rail
-PPG Diff tube
-Ralliart all mount
