Evan's 444whp HTA Green Evo 8.5
The reason why I ask is because the ETS stock replacement manifold calls for a 1.25" if you're under 600hp and 1.5" if you're over 600 hp. Someone on Tri-State Evo put the 1.5" on their stock IX turbo and it actually made the car laggier, thus why I'm surprised that the 1.5 was used in this case and ran fine.
Out of curiosity how did they come to the conclusion it was the header? Dyno testing with back to back timing curves, boost curves, and AFR, or butt dyno? I dont mean to sound disrespectful I am honestly interested in knowing because I was surprised how much faster this was spooling as well. Everything said that it should be worse based on popular opinion, the big plenum short runner intake manifold, larger cams, and the header, yet it was 180* out from expected. The changes here were SD, parts listed, tune. The preload was left the same because we never thouch that without reason and after asking to make sure it was ruled out.
Aaron
I don't remember much of the specifics (since the thread was over a year ago on TSE). Yes, they had the ETS 1.5" installed and that was the most major part changed out. It was done through a butt dyno, but I guess that's not a good form of measurement. However, is there a reason why ETS would list the manifold for different power levels?
Thats what I thought was going on with this one, so we checked preload and even after making an adjustment it seemed to be the same. 3 port got the boost where it needed to be to make the power but its odd that Brett's car (virtually identical build) held 26 through the mid range with just a Hallman.
