Evo 9 MAP 2.4 CBRD BBK-B BB pump gas dyno
Car is nearing completion. AEM meth water system did not function so only 91 octane run was completed. 473 HP, 412 lb-ft at 24 psi.
Mods include MAP 2.4 standard rod,DI IM, Full race prostreet EM, Built head, Walbro 400, Spoolin Up COP, AEM V-2.
http://img687.imageshack.us/img687/9295/3o9b.jpg
Ibelieve this run was 3rd gear, I'll check with my mechanic. I have the Map O2 housing recirculated, GSC R-2 cam. The compression ratio was supposed to be stock 8.8 but on my build sheet from MAP is says 9.7. I got a headache trying to apply Boyle's gas law but I'm assuming with the larger displacement that should get me close to 8.8. Apologies to all you engineers.
We don't have E-85 here so Meth water injection was the only alternative for higher boost.
David.
David.
Evo MAP 2.4 CBRD bbk-bb
I checked with my mechanic and this was a 3rd gear run. Spool is probably helped by the Jack's stage 3 transmission. It has the evo 8 3rd and 4th gear with a 4.00 final drive gear. It's in between a 3rd and 4th gear run.
Thanks for the positive comments.
David
David
I'm very interested in seeing more of this setup. I love the curve...much like the 2nd poster mentioned: it looks like a stock evo curve but just way more power and tq....the response on this must be ridiculous and it will just keeps pulling. That and the fact that you are only at 24 psi once you spray some meth and up the boost and see what timing you can get away with. That said I wouldn't be surprised to see you in the 530-550 whp range.
David.
David.
