Mike's 738 AWHP / 560 AWTQ Evo 8 - Mustang Dyno - Boostin Performance
Mike brought us his beautiful Evo 8 with two main goals in mind - 700+ AWHP on a Mustang Dyno and a low 9 second daily driven, emission compatible Evo. While equipped with a Boostin Performance Long Block, Ported Intake Manifold, Intercooler Piping, and a list of other "go-fast goodies," we were able to reach Mike's goal! The 9 second time slip will be obtained once Spring hits the area and the tracks are open again.
Mods:
Boostin Performance Stg. 3 Long Rod 2.0 Liter Short Block
Boostin Performance Stg. 3 Ported Cylinder Head
Boostin Performance Stock Ported Intake Manifold
Boostin Performance Upper and Lower IC Pipes
Injector Dynamic 2000cc Injectors / Double Pumper
Precision 6466 Turbocharger
Competition Clutch Twin Disc
Ecu Re-flash Speed Density Tune By Devin on E85
Mods:
aside from long rod setup on op car, what do you have different to make additional 50whp? im curious.
is the OP running s3 or STM650 by chance? If not i wonder if he could pick up some gains there. Also is the intake mani just a basic port or is this a full CB/MAP rev3 port?
Hard to tell, the midrange on the OP car is awesome compared the the graph posted below it, yet the top-end falls off a bit more. Could be cam timing, gear used on the dyno, cams, timing fuel......it goes on
Or that the car cant breathe up top due to the stock intake manifold. Great numbers guys I know how anxious Mike was to finish the car I bet he's counting down the days till spring
Boostin Perform
Jan 31, 2015 07:00 PM
Boostin Perform
Jan 21, 2015 10:29 AM
Boostin Perform
Evo X Dyno Results
Oct 6, 2014 06:14 AM
Boostin Perform
Sep 20, 2014 06:54 AM
05-EVO-GSR
Evo X Dyno Results
32
Jul 31, 2014 09:40 PM
