S366 + E85 + mustang dyno = more than you think
It's been a long road getting the car to where it's at now and I'm really excited to see what she will do at the track next month. Any comments or questions are encouraged.
Engine Mods:
2.1L 10.5:1 4G64
GSC S3 cams
Supertech dual valvesprings
Borg Warner S366 w/ T3 .70 AR hotside and billet compressor wheel
XS Power manifold
Tial MVR wastegate
Custom exhaust
STM upper IC piping
AMS 3" FMIC
Tial Q bov
FID 2000 injectors
Buschur double pumper
Fuel Lab regulator
TurboXS manual boost controller
SD conversion
Drivetrain Mods:
Built trans (stock gearing)
Shep stage 2 transfer case
Quartermaster 8 leg twin disc
E85 fuel
40 psi
Stock head
Stock intake manifold
Stock throttle body
Engine Mods:
2.1L 10.5:1 4G64
GSC S3 cams
XS Power manifold
Tial MVR wastegate
Custom exhaust
STM upper IC piping
AMS 3" FMIC
Tial Q bov
FID 2000 injectors
Fuel Lab regulator
SD conversion
Drivetrain Mods:
E85 fuel
40 psi
Stock head
Stock throttle body
Wow nice power, I want a set of FD wheels with QTP,s for my car. How are the BW turbo categorized the 3 stand for the turbine side (T3, T4 etc) and the 66 the compressor wheel size (66mm) ? Or did I just make all that up haha?
Here's the measurements of mine in comparison to a standard 6766.
BW S366
66mm/94.1mm CW
80mm TW
82lb.min flow
PTE 6766
67mm/87mm CW
74mm/66mm TW
93lb.min flow
I love it. Lots of power on a mustang dyno!!!
I fab'd up a top/sideways s366 .91 a/r setup on my duramax.... absolutely loved that turbo.
In the process of building a 2.1 right now, seriously considering putting an s300/s362/s366 on the car.
On the graph you can see it starts to choke out around 7200 and I blame that on stock head/IM/TB. At the track she will have to wrap out 9k in 4th since I'm still on the stock 4.52 final drive. Going into 5th is not an option so for now that's all I can do.
Thinking of going with an eagle crank, manley turbo tuff i beams, and hd wisecos... (I need a crank).
My goals are like 600+ dyno jet whp at 6700ft elevation. Made 575 with an ef4 (with the older crappier flowing 11 blade turbine wheel) on a pos 2.4 so 600 with any 300 series borg on a better revving 2.1 should be pretty easy. Like to make good power and keep the boost reasonable, don't care that much about lag personally.
I'm leaning towards going with the single entry .88 t4 though to keep the manifold I build simple. I know I'll give up considerable spool though so we'll see. And after seeing the insane amount of power yours has made, I really don't think I need the 366. The 300 (60mm) would probably do it!
I was just over 500 on wastegate pressure (26 psi) on pump gas I think that would be perfect if you still went with a 66. That way you have plenty of room in case you want to move up later
the graph layout makes this turbo seem like it has more lag than it really does.
do you have logs of when the car makes 30psi ?
I remember tscomp overlaying this with a 6466 and they mimicked each others power curve.
