Concerns before race weekend
I had my car tuned and should be at 11afr wot. Later found out that I had boost leaks. Since fixing them the car now pins at 10 afr at wot and people say I get some greyish smoke out the exhaust and smells like gas.
I have races this weekend, both drag and autox. Should I be concerned with possibly washing the walls or something equally as bad? Or should I be ok?
Its an 8 with 9 turbo, 10.5 hot side, upgraded piping, ported manifolds, 272 cams, full exhaust on 93.
Any advice would be appreciated!
Contact the tuner to see if he can pull some fuel out of the map.
Or
Get a laptop and a 2.0/1.3 cable and pull the tune. Then pull a small amount of full out of both fuel maps above 200load and reflash until you have the desired AFR. Most people shoot for 11.2-11.5 on pump gas. I personally shoot for 11.5 for the road course since as it heats up the stock ecu will add fuel. A couple gallons of good race fuel is also a good idea.
There are a number of how to video's on tuning an evo if you need the finer details. Here a great series that covers alot.
Or
Or lower your boost. Fixed leaks, now you're over boosting..
Tuner is too busy this week with the biggest race event in MN otherwise I would have bit the bullet and upgraded to a duel tune.
Thanks for confirming my suspicions. Should I turn the boost conteoller down to compensate if I can't find someone with the tuning software before Friday?
An exhaust leak wouldn't cause your A/Frs to go rich either. If you developed a larger boost leak while fixing the others, that could account for what you're experiencing.
Unless you're not on a maf.....
Is your car on speed density? If so you could be hitting different load cells since the boost leak fix and if there are large variations in your fuel map that could be a culprit as well.
We used evo scan to identify how much of leak there was, fixed what we could find and then checked again. There is still a leak somewhere, but it was fairly insignificant. Car doesnt hesitate at all anymore so I would guess that the leak didnt get worse.
Im not familiar with "speed density" but there is still a maf on the intake.
Sorry, let me rephrase. We used evoscan to watch knock and read air flow. We used a boost leak tester to find the issues and the did another scan to see the difference it made. I didnt mean we literally found them with evoscan.
Wideband is on the down pipe so I doubt there is a leak there.
Back to the real question though. If I'm running that rich will the motor be ok under heavy load for 10 to 50 seconds. I only plan on a couple drag runs and a load of autox. Courses over the past three years have been roughly the same and no nore than 50 sec.
Anyway, if you are smoking from running too rich, that's a bit much. Personally, I wouldn't run it hard. But thanks just me.
Arctic02z
Jun 29, 2011 11:38 AM
boostedwrx
Northwest Region
Feb 18, 2011 09:27 AM
682000
Northwest Region
Jul 23, 2008 08:05 PM
leetman
11
Dec 1, 2006 08:38 PM
drizzo1234
30
Jun 24, 2005 06:24 AM
