2.3L stroker power expectations?
Hi guys,
What power output can I expect for my Evo VIII 2.3l Stroker with this spec?
HEAD & TURBO System
- 4G63 Head work, port & polish
- Magnus V5 Intake Manifold, A356-T6 Aluminum Cast, 5L Plenum
- Magnus Adapter plate for Throttle Body
- S90 Throttle body, 74mm
- JM Fabrications Tubular Exhaust Manifold, 49mm runner, twin-scroll, 304 stainless steel tubing and 304 stainless steel CNC machined flange
- Exhaust Manifold Gasket OEM Mitsubishi
- Kelford cams 272, 11 mm valve lift
- OEM Mitsubishi Cam seals
- Ferrea +1 mm Inconel Inlet valve
- Ferrea +1 mm Inconel exhaust valve
- Ferrea Valve guides
- Ferrea Valve locks
- Ferrea Valve stem seals
- Kiggly Racing high presure Behive springs
- Kiggly Racing Titanium retainers
- BDL Adjustable cam gear
- ARP Cam gear Sprocket bolts
- ARP Cam tower bolts
- Intake & Exhaust studs & locks
- Forced Performance „Black“ Turbocharger, Dual Ceramic Ball Bearing, 84mm intake, 82mm Billet Compressor wheel, flow rate 68lb/min, 67mm Turbine wheel, twin-scroll, ported MHI exhaust body casing, 1,7 bar WGA, upgraded Oil-lines
- Ross Sport Turbo Elbow
- Turbo Elbow Gasket OEM Mitsubishi
- NGK Spark plugs, Iridium BR8EIX
- Valve cover Gasket OEM Mitsubishi
ENGINE BLOCK
- 4G63 Engine block Evo Block
- Engine block constructor Norris Designs
- Engine Block Torque Plate Honed to 85,5mm
- A1 Technology Head Studs, H11, Tensile strength 260.000 psi, 1000+whp rated
- Norris Designs Head Gasket 1,4mm
- Forged Stroker Pistons JE, Asymetric, 85,5mm, Part nr. 297048,
CR: 8,5:1 , 272g weight, -22 dome volume, 22mm pin
- Manley Forged Con-rods „I-Beam“ Turbo-Tuff, 150mm, 675g weight, 1000hp rated
- ARP 2000 rod fasteners
- Clevite race bearings and main bearings
- Oil Squirters, Engine block breather/ventilation, 10AN, modified AC Bracket
- Manley Forged 100mm Stroke Billet 4340 Crank, 15,1kg weight, 7-Bolt, „Knife edge“ counter ballance, Part nr. 190120BPL
- ARP main studs
- New OEM Oil pump, seals, oil gallery ported on block
- New OEM Water pump, seals
- Ballance shaft eliminator kit
- New OEM Sump pickup and seals
Parts to come;
- Asnu 1000cc Injectors
- Magnus Fuel rail
- Walbro 450
- SD conversion
- ETS UICP & LICP and 3" IC core
and other bits & peaces....
HEAD & TURBO System
ENGINE BLOCK
- ARP main studs
Parts to come;
- Magnus Fuel rail
- Walbro 450
- SD conversion
100 ron? or 100 AKI?
You'll probably be very comparable to US 93 octane fuel because we use the AKI number. Maybe a little better. I know TScomp has plenty of those results floating around if you do a quick search. Found one for you with 93 octane results.
https://www.evolutionm.net/forums/ev...ms-93-e85.html
You could go lighter on those rods. R&R makes an I beam that is almost 80 grams lighter. I think it's 605 or 615 grams.
Black, if pushed, is good for 700+ horsepower on E85 (more if going crazy). The stoker will let you spool that thing around 4000 to 4200 rpms, depending on how everything nets out.
And if you are going to run E85 or higher octane, you can run higher compression than the 8.5.
Thanks for the info!
Where I live E85 is not available as it is in the US
Therefore, it will be 100 RON.
So, talking numbers with this current setup realistic would be around 500WHP and 600NM tq?
Squid747
16
Oct 17, 2018 03:27 AM
EvilTechnology
Apr 6, 2013 09:33 AM
