JDM EVO 7 2.4 Block with Turbolabs 35r 93oct
Old Sep 1, 2015, 06:06 AM
wana-B-racer's Avatar
Dyno Results of JDM 7 with 2.4 on 93oct with water/meth
30 psi
4G64 block
Port and Polished EVO 7 Head
GSC R2 cams
Vishnu Cam Gears
GSC 5041 Springs and Retainers
OEM Valves
AMS Head gasket
Manley Stroker pistons 86.5mm 9:1 Compression
Manley 156mm H-Beam Rods
ACL Bearings
Balance Shaft Delete
Fluidampr Pulley
Tomei Baffle plate
OEM Intake manifold
OEM Throttle Body
Aeromotive FPR
Forced Performance Exhaust manifold
Turbolabs of america GT35r reverse scroll turbocharger
Ported 10.5 backend
MAP O2 eliminator downpipe
JAZMA jdm cat back exhaust
Torque Solutions Motor Mounts
Treadstone 1045 Intercooler
FAB Short run intercooler piping
ID High Z 1000cc Injectors
GIZZMO EBC
Stock ECU
Water/Meth Kit
COP System
Samco Hoses
ACT Clutch
ACT Pressure Plate
ACT Flywheel
What you all think?
Torque kinda drops off too soon?
What do you all think is causing it?
Attached Thumbnails JDM EVO 7 2.4 Block with Turbolabs 35r 93oct-20150826_214046.jpg
Old Sep 1, 2015, 06:56 AM
ReaperX's Avatar
What does the boost taper off to?
I would have expected a bit more out of that combo with the water/meth and 2.4
Old Sep 1, 2015, 09:31 AM
cvnick's Avatar
I am having sort of the same issue right now. i also have a turbo lab "35r" however mine is made from a evo 8 core not a 9. i am currently sitting at about 480whp but my tuner mentioned that the turbo is running out of breath. after a lot of research and contacting turbo lab they actually told me if the turbo is based of the evo 8 core, they found the compressor cover to be a restriction and could not make over 500whp with any of them. they offered to upgrade it to a evo 9 chra and anti sure cover for a good price which is what i may be doing if i dont go with a t3 setup. find out if your's is a evo 8 core or a 9 then go from there.
Old Sep 1, 2015, 10:35 AM
lancerrally45's Avatar
Seems low. On my stock evo 8 turbo and 9.8 hotside i made around 470ish tq and 410ish hp. Same block setup. Granted I would hit 34psi and bleed to 23. Not recommended.
Old Sep 1, 2015, 10:39 AM
Actually did not see any taper. Held 30-31 psi for the entire run.
This is the Turbo
Old Sep 1, 2015, 10:41 AM
Says white on the cover but it was modified to fit a 60 x 83 compressor wheel with a tdo6h4r turbine
Old Sep 1, 2015, 11:24 AM
ReaperX's Avatar
Something just aint right with that turbo if you're only making that power at a flat 30psi.
Old Sep 1, 2015, 12:44 PM
Could it be tuning?
Old Sep 2, 2015, 05:21 AM
Originally Posted by wickedevors
nice numbers for pump gas
Not at all.
Old Sep 2, 2015, 01:53 PM
ReaperX's Avatar
Originally Posted by wana-B-racer
Could it be tuning?
Hard to tell without seeing the maps. I made 396/355 on a MD with the same correction factor as you with a 71hta, stock bottom end and similar bolt-ons at 26psi peak and 25psi up top. So on a DJ that would be 435/390.
https://www.evolutionm.net/forums/ev...1hta-evo8.html
Another person made 400/354 with 1-2psi less than me on the same turbo.
I would assume something that is considered a 35r to be 500+ on 93 with a 2.4 at 30psi with water/meth.
Old Sep 3, 2015, 11:00 AM
awhit17's Avatar
Yeah look at my graph, stock 2 liter, pump 93. 24psi spike 23 out the top. Something is not quite right with yours IMO
Untitled by Alex Whitacre, on Flickr
Old Sep 5, 2015, 07:10 AM
WikdEvo's Avatar
How are the cam gears set up?
Old Sep 5, 2015, 07:51 PM
Will take a pic tomorrow
Old Sep 9, 2015, 11:42 PM
CT9A PR's Avatar
I have used that turbo and made 490 whp on 91 octane on a 2.0
Weird you are having issues with your set up or crappy tune
Check for boost leak or poor wga
Old Sep 12, 2015, 05:37 AM
rip
rip's Avatar
How is the water meth set up?
Boost, ign?
Quick Reply: JDM EVO 7 2.4 Block with Turbolabs 35r 93oct
