Stock turbo Evo 9 Dyno your thoughts
My 2006 Evo 9 bought it used from dealer im the 3rd owner zero mods when I bought it so dont know if it was previously modded,, 72.000 miles
Just dynoed it on a Dynopak E85 peak boost 28/29
Stock turbo, stock intake manifold, stock tb, stock head with ARP STUDS, stock block
MODS
GSC S2 Cams / springs and retainers
1000 Fics , walbro 255
Jm fab o2 hood dump, 3 inch turbo back , test pipe
Ets 3 1/2 intercooler, injen upper and lower ic pipping , injen intake
3 port boost controller , open source tuning
Tuned on e85
Dyno Attached
MODS
Tuned on e85
Dyno Attached
Seems pretty high, even for the RRE dynapak.
Numbers seem off. I have a Evo IX with a FP 71hta on E85, tuned at 30psi, running full bolt-ons (including a 02 dump), and I put down 450whp and 400wtq on the stock block and head studs on a dynapack. I'm also on stock cams, but regardless these numbers seem very high. UNLESS, you were lied to and this has a built motor and is not stock like you were initially told
Also here's some food for thought. I was talking a local tuner who also has a dynapack. He was telling me that dynapacks used to read a little on the high side similar to how mustangs read on the low side. He told me that they offered a software update a while back and now they read within 1-3% of a dynojet. I can personally attest to this as my car has been on both a DJ and a DP and it puts down almost identical numbers on both. It's possible that this dynapack doesn't have that update.
Bought the car from CarMax and highly doubt they know much about the car They probably bought it threw auction, I'm the 3rd owner
This is my second Evo 9 that I have owned and my previse evo 9 with similar mods with hks cams and stock o2 housing stock turbo only made 424/414 same dyno same boost e85, So ya I was surprised with these numbers also
Just thinking of some ways without tearing her apart.
Ya my friend has a shop nd works on evos so I'll have him check it out Hey what do think about how the stock turbo is spooling according to the Dyno it's at full spool by 4k I thought 9 turbo spool a little earlier can this be from the cams GSC S2
[QUOThiE=lancerrally45;11562601]Check the engine code, see if its a 4G64. Another way to check the deck height, put a timing cover on the top portion of the timing belt and see if the lower holes line up. This is an easy way to tell if you have an added 6mm of deck height.
Just thinking of some ways without tearing her apart.[/QUOTE]
TommiM
Sep 1, 2010 09:04 AM
recompile
10
Apr 9, 2009 02:44 PM
4g63girl
Mar 17, 2009 01:46 PM
DynoFlash
92
Jan 25, 2008 07:59 PM
DynoFlash
33
Jul 20, 2007 05:11 PM
