2.4LR ETS T3 6266 turbo kit GSC S2 93oct
Old May 6, 2016 | 05:17 PM
tscompusa's Avatar
After countless attempts to get Doug's Evo tuned and running into issues, we finally nailed it. Doug ended up having to add a 2nd wastegate to his old ETS exhaust manifold due to boost creep issues.
Due to rain we did the tune on the dyno, and it turned out exactly how I expected. Remote/email dyno tuning is nice, because we are able to get pulls done quicker and more efficient, but of course isn't necessary.
After the dyno session it was dry, so I had Doug go out and do a pull with the tune directly off the dyno as well, and we got both VD results in dynojet mode, and the actual mustang dyno results.
Mods are:
2.4LR
CBRE Ported head
GSC S2 cams (non billet)
Buschur ported intake manifold
Buschur ported 65mm TB
ETS FMIC / Tial Q bov
Bosch 2200cc injectors @ 61-62% IDC
Dual Aeromotive 340lph in-tank / -8 feed
ETS T3 Turbokit /w two 44mm wastegates
Journal Bearing PTE 6266
Tephra v7 speed density /w mbc
579whp / 494wtq on the Mustang Dyno
619whp / 532wtq on VD dynojet mode
Graph of VD & Mustang dyno below:
Mustang (Smoothing of (20):
VD (Dynojet mode):
Few cool pictures taken during tuning:
Old May 6, 2016 | 05:42 PM
rotaryboxer's Avatar
I can't say enough about Tom's customer service and patience. We ran into fueling issues on initial tuning session which was fixed only to discover that the manifold needed a second WG to keep the boost in check and then a failed 3 port solenoid led us to just stick an old fashioned MBC to get this tuned today. Street tuning preferred but weather wasn't cooperating so Command Performance hooked me up with the dyno for the day so Tom could work his magic and magic he did. Car feels amazing on the street.
Thanks again,
Doug
tscompusa (May 9, 2016)
Old May 6, 2016 | 06:21 PM
alpinaturbo's Avatar
Cannot see graphs
Old May 7, 2016 | 04:12 PM
Freddy302's Avatar
Average power is awesome for 93 oct! Love the "e85" boost levels on pump gas... Give us guys hope who dont live near e85
Old May 7, 2016 | 04:42 PM
Tom
I cannot believe the power on 93��
Love how low backpressure efficient full frame allows timing and boost even on 93.
Old May 8, 2016 | 05:17 AM
I think it has a bit more in it on pump if I had the Fp5r cams back in it or a set of GSC S3 cams and a better intake manifold. Believe it or not I am pretty sure the car is running knock free at this point and probably had another psi or two but I didn't want to push it myself lol. To the E85 point I have two stations total in my state both 40 minutes from my house so e85 was possibly I guess for tuning purposes but not practical at this time.
Old May 9, 2016 | 12:22 PM
tscompusa's Avatar
Thanks again,
Doug
Thanks Doug! Pleasure working with you. I'm glad we were able to both work together and finally figure this car out!
As I was tuning this, I thought of you haha. I knew you would comment if you seen this. You love 93oct.
I stopped adding boost/timing before the vehicle even started to knock, there's more in it yet.
Originally Posted by alpinaturbo
Tom
Ya it took good timing & lots of boost! We had to spike the boost down low in order for the mbc to hold up top, but no knock throughout the entire tuning session.
It has more in it. I could get it over 600 on that mustang i think, but it would require a 3 port that functions properly to bump the top end up. I wouldn't want to spike any higher boost then what it is now on 93.
A bigger set of cams would definitely make it more efficient as well no doubt.
black E (May 13, 2016)
Old May 9, 2016 | 07:28 PM
Lexus01IS's Avatar
Great power Doug
Old May 13, 2016 | 03:29 PM
Evo__Lee's Avatar
Replacing S2 cams!
Would you be able to guess a # in whp/wtq gains from replacing the S2 with R2 Cams with this particular platform on same boost levels?
Old May 15, 2016 | 08:16 AM
Man...you make me want to throw my FP5R cams back in and put a new 3 port on it...tempting since I still have the car and cam swap is easy.
Old May 18, 2016 | 04:14 AM
tscompusa's Avatar
Around 8-10% more power.
ETS Michael
ExtremeTurboSystems.com – WA
Nov 29, 2021 08:32 PM
tscompusa
Oct 4, 2016 01:08 AM
Spec-OpsMotorsports
Aug 27, 2015 06:04 AM
tscompusa
May 3, 2014 04:54 PM
tscompusa
Aug 31, 2013 07:40 PM
