EVO 8 CBRE 2.0 6466 1450's E70 37PSI
Old Sep 15, 2016 | 10:53 AM
STLEVOIX's Avatar
Car started here with stock turbo then swapped to a MHI FP RED JB
https://www.evolutionm.net/forums/ev...turbo-e70.html
Car is still on factory fuel lines and factory regulator. FIC 1450's are at 99% duty cycle maxed out. Fuel is E74-E75 pump. 37PSI @ 11.5
CBRE 2.0 9.5:1
CBRE Head
CBRE Intake Manifold
GSC S2 cams
PTE V-band 6466 .82
Fic 1450's
Double pumper
Grimmspeed 3 port
Shep tcase/trans
Stock ECU w/ Tephra
Best car went was 11.7 @ 132 w/ a 2.1 60 foot
Old Sep 17, 2016 | 04:29 PM
EvilTechnology's Avatar
Very nice! Hows it feel?
Old Sep 17, 2016 | 07:50 PM
STLEVOIX's Avatar
Car feels great! Definitely laggier then my old fp red setup, but hits harder and pulls harder. Happy i made the switch
Old Sep 17, 2016 | 07:52 PM
STLEVOIX's Avatar
Did test and tune today at Street car take over here in STL. Was fun, but I could not compete with the GTR's
Old Sep 17, 2016 | 07:53 PM
STLEVOIX's Avatar
Originally Posted by STLEVOIX
Car started here with stock turbo then swapped to a MHI FP RED JB https://www.evolutionm.net/forums/ev...turbo-e70.html Car is still on factory fuel lines and factory regulator. FIC 1450's are at 99% duty cycle maxed out. Fuel is E74-E75 pump. 37PSI @ 11.5 CBRE 2.0 9.5:1 CBRE Head CBRE Intake Manifold GSC S2 cams PTE V-band 6466 .82 Fic 1450's Double pumper Grimmspeed 3 port Shep tcase/trans Stock ECU w/ Tephra Best car went was 11.7 @ 132 w/ a 2.1 60 foot
Updated numbers, back to back 3rd gear pulls. You can see it starting to go lean. Injectors maxed out for sure.
Old Oct 5, 2016 | 12:32 PM
STLEVOIX's Avatar
Small update. FIC 2150's waiting to be installed, along with a -8 fuel feed line. I am building a new double pumper with AN fittings as well. Going with brand new pumps. A 255 as primary and a 450 as the secondary activated by the hobbs switch. Not going to be doing a rewire. Also have a Fuel Lab AFPR that will be installed. I pulled the transfer case and sent it out to Jack's to be rebuilt to handle the increasing power level as well.
Old Oct 6, 2016 | 10:50 AM
Awesome!! Nice to hear
Old Oct 6, 2016 | 05:49 PM
Teal2nnr's Avatar
I thought the MPH would have been higher with that amount of power. I guess we'll see what it can do with the fuel upgrade.
Old Oct 7, 2016 | 09:10 AM
STLEVOIX's Avatar
I have stock final overdrive. If i had a 4.11 in sure the mph would be higher
Old Oct 8, 2016 | 05:10 AM
Migsubishi's Avatar
Your going to keep the ix transmission right, just add a 4.11?
Old Oct 10, 2016 | 08:31 AM
STLEVOIX's Avatar
4:11 is going to happen, but not for a while. My transmission now has 0 issues and shifts like butter, so I am not going to touch it for the time being. The transfer case arrived at Jacks on Friday. I am opting for the Stage 3 Indestructible, which has a bout a month turn around time.
Old Oct 10, 2016 | 11:27 AM
Teal2nnr's Avatar
A 26" QTP should help your MPH a lot.
tscompusa
Mar 20, 2017 08:33 AM
tscompusa
Oct 29, 2016 03:50 AM
murlo26
Evo X Dyno Results
63
Oct 19, 2010 03:05 PM
AWD Motorsports
Jan 7, 2010 12:15 PM
AWD Motorsports
AWD Motorsports - Florida
23
Jan 6, 2010 12:18 PM
Quick Reply: EVO 8 CBRE 2.0 6466 1450's E70 37PSI
