Post exact weights of weight reduction you have done!
Old Jan 9, 2012, 04:58 PM
  #601
RazorLab's Avatar
Received 1,056 Likes on 764 Posts
Originally Posted by badev0
I know the 05+ RS has the aluminum door crash beams. No GSR's do.
I believe all 04+ Evo's have aluminum door beams.
Old Jan 9, 2012, 05:02 PM
  #602
mullen's Avatar
chris just go to cf doors
Old Jan 9, 2012, 05:44 PM
  #603
StreetThisEvo's Avatar
Originally Posted by evodan2004
dinner sucked.
i got the bar out. it weighs 20.8lbs. time to start modifying.
Can you take a pic of what it looks like once it has been removed and post it up. Or send it to me and i'll post it up.
Old Jan 9, 2012, 06:00 PM
  #604
badev0's Avatar
Old Jan 9, 2012, 06:37 PM
  #605
^^ So is that a modified version done by AMS? It looks to short.
A lot of weight can be cut off of that bar and it can be re-installed. All you really need is the steering rack support and the radio/hvac supports.
Old Jan 9, 2012, 06:43 PM
  #606
badev0's Avatar
Yes it is. It does looks short in the picture but it is the correct length:
I'm going to pull mine off in few weeks and cut all that BS off.
Old Jan 9, 2012, 06:51 PM
  #607
EvoDan2004's Avatar
the pass air bag on my scale said 7.3lbs. i was told it was 6lbs. so im happy with that.
as for the bar there is so much that can come off it and not loose any of its ability to hold what it needs to hold. the problem with that straight piece posted above is its 1 size. what i mean by that is the stock bar is 2 sizes. the passenger side part is smaller then the driver's side. so just re welding the brackets and stuff back on will not work out properly. ''i dont think it will''
i am going to order both sizes i need in something light. maybe some thin wall chromoly or something. and then weld everything back to its location that i need to reuse for mounting.
as for the wiring behind the dash. i started with that. i just removed all my dumb gauges and turbo timer and wideband. im to ''ricer'' to let that stuff go so ill just shorten everything and while the dash is out i will run everything properly and make it very neat looking.
as for the steering column. i got a few idea's.
o yea. i had Chinese food for dinner. it was delivery and every time i order from this place i know my food suck's. but im so damn lazy to drive 5 minutes to the good Chinese place i rather complain and order it haha.
Old Jan 9, 2012, 06:52 PM
  #608
EvoDan2004's Avatar
you want a pic of the stock bar out of the car? i can do that. give me a minute.
Old Jan 9, 2012, 06:54 PM
  #609
EvoDan2004's Avatar
the pic you saw is better then any pic i can take.
your going to need the brackets on the sides that hold the dash as well. i would not give up 1lb is brackets to have my dash flex around and radle like hell
Old Jan 9, 2012, 07:38 PM
  #610
EvoDan2004's Avatar
here are some pics. this is bone stock. un modded.
Old Jan 10, 2012, 06:22 AM
  #611
boomn29's Avatar
^^ And what's it weight (bone stock)?
Old Jan 10, 2012, 06:55 AM
  #612
EvoDan2004's Avatar
20.8 lbs
Old Jan 10, 2012, 09:42 AM
  #613
EvoDan2004's Avatar
i really wonder what my girlfriend thinks of me when she looks at me with all the crap i do. from my modded rear sub frame and now this dash bar i can only imagine her thoughts.
stock bar 20.8lbs. 15 minutes of evodan modding 18.8lbs. all i did was remove a few things i dont need. i still have a few things i can do before i send it off to have the main bar remade and welded all back together. i bet in the end i can get it down to 15lbs and maybe more. not to shabby for a bar that will remain 100% useable. every bit counts. i still need to run a 9 second pass.
Old Jan 10, 2012, 12:00 PM
  #614
03whitegsr's Avatar
Originally Posted by 03whitegsr
I weighed the dash bar, 19.8 pounds.
From what I hear, you can get about 4-5 pounds out of it without affecting anything.
Just to bump this idea back up...
The majority of the weight in that bar looks like it's in the mounting plates on the ends and the steering column.
For those looking to stay in a class though, I would bet changes to the steering column puts you into a different class. I'm really considering biting the bullet, dropping 200 pounds (doors and steering column) the easy way and heading to a different class.
As for new ideas, I've got a couple that I'm currently working on that I haven't seen done yet. One of them will reduce unsprung weight by about 20 pounds. Another drops about 10 pounds off the engine. I've got materials coming for both and I'll post up when the prototypes are functional.
I'm after weight in two main areas, weight that moves relative to the chassis, and weight infront of the firewall. The back is where weight is going if I can move it out of the front but still need it.
Old Jan 10, 2012, 12:03 PM
  #615
badev0's Avatar
Post pictures of it when you are finished
Quick Reply: Post exact weights of weight reduction you have done!
