Installing autopage rf520
Okay this is where we are now..
italics is already connected and working
Bold I need help knowing where to connect
Gray is what I am omitting for now (not connected)
Car: 2006 Evolution IX
Alrm: Autopage RF-520 no remote start
Red Wire: +12V main power -> white (+) ignition /wires at the column
Brown wire:(+) Siren output -> siren from engine bay
White Wire:12V Parking Light output -> green/white (+) fbox
Orange/Red Wire: Dome Light relay Output -> White (-) fuse box
Black/Green Wire: 200mA (-) Channel 3 Aux
Gray/Red Wire: 2nd Channel trunk release Power input ->dont have module
Orange Wire: (-) 500mA Ground when Armed output -> KEY SENSE WIRE
Gray Wire: 2nd Channel trunk release Relay output -> dont have module
Black/blue Wire: (-) 200mA Channel 4 Aux
Black Wire: (-) System Ground
Violet Wire: (+) Possitive door trigger Input
Green Wire:(-) Negative door trigger Input -> white wire (-) fuse box white plug
Black/Red Wire: (-) 200mA Channel 5 Aux
Black/Violet Wire: (-) 200mA Channel 6 Aux
Pink Wire: (-) 2 step unlock / factory disarm output** -> Where too/how
Blue Wire: (-) Negative instant trunk/hood trigger -> Green/Orange in the trunk
Red/White Wire: (-) 200Ma HeadLight illimination output** -> where too/how
Brown/White Wire: (-) Horn output -> blue/red (-) horn swith
Yellow Wire (+) 12V Ignition Switch input-> black/white ignition
DESCRITIONS OF WIRES I NEED HELP WITH:
**Red/White Wire: (-) 200Ma HeadLight illimination output:
"This wire will operate the vehicle's factory headlights when integrated with a relay. this output supplies a 200mA negative (-) that will turn the vehicles headlights on 30 secs. when armed and disarmed."
**Pink Wire: (-) 2 step unlock / factory disarm output:
"The 2 steps unlock feature will work for the most fully electronics doorlock circuit. the vehicle must have an electronic door switch, which locks and unlocks all of the vehiecle's doors. When wired for this feature, press <unlock> one time, te alarm will disarm and unlock the driver's door only. If you press <unlock> two times with in 3 seconds, the alarm will disarm and unlock all doors"
The above a two features i bought this systems for orignally when I had it in my previous car, and the installer today did not install... I went over all the wiring and realized i could've done this myselft; he only charge me 50 bucks. =)
so far my car locks and unlocks all doors with the alarm transmitter, and I know the answer lies within the PINK wire but Im not sure if maybe i need to substitute it for the GREEN unlock wire? or if it needs to be connected somewhere...
