Post Your Custom Sub Enclosure Here!
the box was a ***** to fit snug, and I have no trunk space whatsoever, which I never used the trunk anyway, the snowboard goes on the rack or backseat anyways, but Overall im very pleased with how it turned out.
here are the pics of the box out of the car, this is the original box before the mold was pulled so this one is slightly heavier (probably about 15-18lbs) but the duplicates off the mold weigh in at about 10-12 lbs Let me know what you think
EDIT: It does fit a 10" or a 12"
Where are the connector's for the speaker wire ??
OOO! Me like very much. Question, could you do one for each side with a pair of 12W6V2's?
that side mount box is sick but holy **** $270 shipped? thats a little crazy... i believe a sub is only as good as its enclosure but i can't justify a custom enclosure that costs $100 more then my sub (IDQ12)...
The terminal cup goes on the rear of the box and no it does not interfere with the box mounting. We only make a driver's side box at this time, if there is enough demand for a passenger side as well we'll produce that one.
$270 shipped may sound like a lot, but walk into any custom shop around and tell them you want a fiberglass box to sit in the side of the trunk and i guarantee you they will quote you double that amount. Keep in mind this box is made from industrial grade fiberglass sprayed out of a chop gun and was built using a $600 woofer (JL W7), but that only means it's going to make woofers half it's price sound that much better.
yea how does that sound...and what exactly are you running?
