Viper 791xv question
Old Feb 14, 2007, 12:48 AM
ntwaddel's Avatar
Hello,
I put a Viper 791XV alarm in my car. I did not hook up any of the remote start stuff. I didn't even put in the remote relay pack. The question I have is, after something is faulted, say the door opens when the alarm is armed. After i disarm it, the light keeps on blinking, and it keeps letting me know the door was opened. How do you reset the alarm after a fault? The book makes it sound like it resets after you turn on the ignition. The problem is, on the main harness I don't see any ignition wires. Does this make any sense?
Old Feb 14, 2007, 02:37 PM
ntwaddel's Avatar
anyone?
Old Feb 14, 2007, 02:45 PM
Inspite's Avatar
Are you sure your not in Valet mode?
Old Feb 14, 2007, 03:17 PM
ntwaddel's Avatar
how can i tell? do you know if i need an ignition switched wire for the alarm to function?
Old Feb 14, 2007, 03:23 PM
BillAce's Avatar
You do not have an ignition source connected to tell the system the ignition is on.
Did you connect the 18 gauge yellow wire to ignition? What about a starter disable?
Old Feb 14, 2007, 03:29 PM
ntwaddel's Avatar
Isnt the yellow wire on the 7pin harness that connects to the remote relay? I don't have the remote relay even connected currently since I was not interested in remote start or starter kill.
Old Feb 15, 2007, 12:51 AM
ntwaddel's Avatar
Ok i have that taken care of. My next question is, on the shock sensor that it comes with, it does not chirp when it is bumped. it is the dual stage, so there is supposed to be the warning chirp, then the full alarm. the full alarm works, but no warning chirps. Does the green wire need to be connected for that?
Old Feb 15, 2007, 07:39 AM
NoTec's Avatar
You probably plugged the harnes for the shock sensor in the wrong way. The end with the green wire connected to the plug should be connected to the brain. That means the open end of the green wire should be towards the shock sensor. The end plugged into the shock sensor should have the wire looped to the blue one I think. You don't need to connect the open end of the green wire to anything.
Old Feb 15, 2007, 09:44 AM
ntwaddel's Avatar
I think you might be right! I will go take a look. I think I have the looped wire at the shock sensor, not the brain.
Old Feb 16, 2007, 06:49 AM
NoTec's Avatar
Sorry if my last post was a little unclear. The plug with the green wire looped to the blue Should be connected to the shock sonsor. If it is already done that way then you have anothet problem.
Old Feb 16, 2007, 02:02 PM
ntwaddel's Avatar
Hmm yeah it looks like the loop side is connected to the shock sensor.
Old Feb 16, 2007, 07:17 PM
MConsoliA4's Avatar
try adjusting the attenuator on the side of the shock sensor, it might be too sensitive, a little less sensitive should make a moderate knock cause the warn-away chirp
Old Feb 17, 2007, 02:38 PM
NoTec's Avatar
Forgot about that. Normally, the knob is only at the halfway point and I usually leave it there because its sufficient. Every now and then it gets tweaked.
Old Feb 18, 2007, 08:49 AM
ntwaddel's Avatar
whats the best place to mount the shock sensor to? should it be mounted on metal? plastic? should i use double sided foam tape or just zip tie it right on there? I don't think I am getting enough sensitivity off whatever it is mounted to.
Old Feb 18, 2007, 04:28 PM
NoTec's Avatar
I normally mount them to the ignition harness in an inconspicuous area.
