Lightweight Fiberglass Subwoofer Enclosure In The Works!
7/19 Update!! - Enclosures for sale, please refer to sales thead found here for further details.
7/11 Update With Pics!! Page 2
Hey guys!
We're new here but have been in the audio business for 20+ years, it wasn't until just recently (2 years ago) we left the main stream install bays to start our own custom audio business - Audio Integrations.
We mainly specialize in the custom fabrication & design of systems and have just recently released our own line of lightweight vehicle specific subwoofer enclosures called "Perfect Fit Enclosures"
Having a Subaru WRX as our shop car that was the first model we started with, we now have both 12 and 10 inch models for Impreza sedan's and wagons from 02 - 07.
We recently had the chance to start work on our newest model - the Evo 12 inch Perfect Fit Enclosure. We're just finishing up with the final details and they'll be released here shortly.
We just wanted to start this thread as a little introduction and give ya a heads up on another possible enclosure option for ya. Once we get the final price worked out we'll post a thread in the "Vendor For Sale Section" with all the details, please direct any sales questions there and not on here.
We had a lot going on in the shop at the time so we didn't get a lot of pics of the process, but here's a couple.
We've done a lot of custom enclosures and installs over the years, so if you guys have any questions on materials used or techniques for your own projects don't be shy asking, we'll do our best to help out. You may also want to check out our Portfolio located on our website for design ideas, we have complete installs as well as separate sections for headunits, enclosures, door/kick panels, & plexi work.
We'll keep ya updated on the enclosure work & release as we move foward.
Thanks - Todd & Ryan
Here's a shot of the back cavity being layed up
and all done! sorry we didn't get the between shots - this is the original in primer ready to start the mold work
and a couple more
Hey guys!
and a couple more
www.audiointegrations.net
Two ideas:
One- install in the passenger side, removable to access washer bottle. Weight distribution would be better.
Two: carbon fiber option?
This is a great idea since I had my heavy subwoofer bouncing all over the place until I recently strapped it to the spare.
Thanks
Thanks
Oh questions questions questions. I am curious about a few details on this box...
Did you manage to find the OEM carpeting?
What is the internal volume?
Wall Thickness?
What sizes will it be available in? (10/12)
And finally how long should this take?
I have to say I am very intrested in this box, and might just want to grab the first one to roll off the assembly line!
Thanks,
James
oh and pics pics pics!
Wall Thickness?
Thanks,
James
Two ideas:
Thanks
Thanks
We're using some existing holes in the side panel to mount a couple of bolts, the enclosure simply slips over the bolts ends and you apply a nut/washer/rubber washer combo from the inside of the enclosure to secure it. Once the subs loaded you can't see anything.
We can look into the carbon fiber option, although it probably won't be too cheap. Carbon's pretty expensive anymore and using it correctly takes time and extra steps. Once we get the standard option of carpet setup and out there we'll look into it.
Wall Thickness?
Thanks,
James
Wall Thickness?
Thanks,
James
We'll post some pics here soon so you can see the difference. The factory doesn't actually use carpet for their trunk liners, its a plastic panel thats heat formed and has a fabric like finish to the one side. That's why it's hard locating the exact match.
We haven't been able to determine the exact internal volume yet, once we recieve our first part back from the fiberglass shop we'll be able to measure the volume, we were shooting for 1 to 1.25 cubic feet. We'll see how close we were here shortly.
It depends on the location but for the most part the wall thickness will be between .25 to .375 inches. The back of the enclosure is molded to the contours of the trunk liner which adds a lot of strength with all of it's curves. The only flat part really is the bottom, where we added three recessed ribs for strength. Flexing won't be an issue , every enclosure gets checked before we put the finishing touches on em, if we find there's ever a shortage of strength it will go back for more glass work.
Based on our Subaru enclosures the 12 inch models are the most popular, that's what we started with on the Evo's. If there's enough demand we'll look at building a 10 inch version. There's a lot of time and money that goes into the original and mold work for a new model. There really has to be a fair amount of interest to justify the work. We'd like to build a 10 inch version so hopefully there some interest in em.
As far as time we're waiting on our fiberglass shop right now to recieve the first part back, hopefully sometime this week. We have to put it through some tests and check fitmet to make sure everything is okay, if all goes well we'll just have to put the finishing touches on our directions and get them on our website.
I'd like to say a week, but with everything we have going on it may be two. We'll get it available asap though!
Thanks for the questions, hope this helps some.
- Todd
When we first introduce a new model we put em on a pretty good sale. Final price will be depending on what we hear back from our fiberglass shop.
Here's a couple links for ya guys -
Subaru models
Customer Testimonials
NASIOC Customer Reviews
EvoM Community Team
No one has asked the obvious question. How much does the box weigh? They say "light weight", but how light weight? And why do a clone of MConsoliA4s box? Try to do something different. Like passenger side (which folks have already mentioned) or something that fits directly behind the back seat and fires to the rear of the trunk.
That would add quite a bit of weight to the left side of the car. And amplifiers come in many different sizes and shapes. Im sure they could do a custom job like that for someone who is having them do the install.
We've started our "Perfect Fit Product" line probably before MConsoliA4's boxes were being made, it's not untill just recently we were able to start work on our Evo model.
The biggest problem with any part made is the start up costs. We, like many companies, have to start with what appears to be the most popular option, and then move on from there. Most customers are not going to want to unbolt their sound system everytime they need to add fluid to the washer. Generally there's more people out there that want to keep the drivabilty of their cars over some weight balancing benifits that would be gained from a passenger side model. Most guys that are really driving their cars to the limits (autocrossing or track use) pull all the extra weight out anyway, no stereo at all.
Our enclosure's aren't for everybody, we make extremely high quality products/installs and follow them up with execellent customer service but there will always be potential customers that our setups just won't work for. I quess that's just the reality of it, if certian models seem to work and there's enough demand for other options then we'd more than happy to look into em.
- Todd
