Help with Orbital Install
So i decided to wing my orbital install w/o the "instruction sheet"
Everything is going smoothly until i try to put the HVAC controls back into place in the lower compartment. The metal dash bracing in the lower part is directly in the way of where the TEMP (black) cable wants to go. Does this kit require me to modify that bracket as well? I have an 06 MR and there is a black rubber radio mount located down there as well that is pretty much in the way, is this because of the gauge kit??. I unbolted it and it kind of bends out of the way but it is defintiley not good.
Can anyone scan their orbital instructions?? Help a brother out?
Not that I found. I dont have the instructions anymore so I cant look at them again. IIRC it said to maneuver them down there, but I sure as hell couldnt figure out a way. I just cut it and called it a day. Makes things sooo much easier. Did your buttons for defrost, a/c, and recirc work wel with no modifications. I had to sand those openings also. The fit was decent on both kits, but the finish was terrible, not what I expected for that much money.
HAHA!! NO the damn button housing was being pushed against and the A/C and RECIRC button would not pop back out once i pressed them in....
SOO i got to sanding the opening, after about 4 tries ( and one broken PEG later) i figured out that it wasnt the opening but rather the bottom part of the bezel that was some pretty thick plastic pushing against the button housing. I got out the dremel and went to town, things fit now!
The guy that sells them seems pretty honest though... it might cost him around 300 bux to pay for the tooling to build the kit. He is also mentioning that a huge audio company might buy the copyrights to his product and if so he will offer a free upgrade to the better version!!! Sounds good to me!
You are right, there is no way that damn HVAC piece is gonna fit unless i get out the cutting wheel.
Haha, mine did the same thing!!! I finally found that a wedge of wood under the heater controls made it work! So ghetto, but it worked. I also broke a damn peg, terrible design how they are part of the mold, which is like body filler and super thin.
....show pix of final install
NOTICE how the black temp control cable wants to be exactly where the metal bracket lives (THIS IS WITH THE METAL BRACKET UNSCREWED AND BENT OUT)
SOLUTION:
Where i cut, it left a lip so that the top part sill rests on the bracket that was untouched ( i put some electrical tape behind to avoid squeeks, i hate squeeks) AND if i needed i could bolt the bottom piece back into place.
And Finally: (boost gauge on my side)
I have been doing the car audio thing for 5 or so years so i figued this would be a breeze, probably took me 4 hours just because i am a slow worker and like to get everything perfect. Once i make a trip to circuit city tomarrow i will have my alpine + sirius in the car instead of the crap factory unit that get static from radio stations only 30 miles away GOD I hate fm radio. Hopefully i will pull the trigger on a 2DIN navi unit sometime in the future (if the wife allows)
SOLUTION:
haha, I just wanted it done. I was doing it in between cars, and just wanted it in. I also do car audio, for about 2 years. Its always personal cars that are rushed and done half-***, at least for me. After spending time on customers cars all day, my car is the one that suffers, haha. I too assumed this would be easy since I do it every day, but took me like 2 hours of grief to make it work. The HVAC was the hard part, only took like 20 minutes to get the radio in. Ill post some pics of it all done soon.
sweet mother of god, this is what I have been looking for for the last month!! I too have an MR with the mysterious bracket in the way, I actually cut the white hvac control box some and JB welded the cable to the smaller post. Anyway, it's acting up again now.... That bracket comes out?? I thought it was structural. Im going to remove that thing right now (1:31 am ) and get a cutting. I sanded the hole down too!! Then figured out its those plastic braces under the HVAC stopping the button springs!!. What a pain in the ****. This thing really needs an "MR specific install manual". Crap
Thanks felickz for informing me of this thread!!
Yeah, Orbital advises that you just bend those old HVAC brackets upward instead of cut them out. Just incase you want to uninstall the relocation kit someday and put the old stuff back in.
Good luck!
Good luck!
TempeRacerGuy
Sep 15, 2007 04:43 PM
johnsrt4
11
Oct 20, 2006 11:50 PM
Rich@Orbital
Evo 'For Sale' Exterior Styling
15
Oct 2, 2006 10:04 AM
