Where to mount Kenwood EQ
Anyone have any advice on where to mount my Kenwood KGC-4042A? The size dimensions are 3-1/2"W x 1"H x 5-3/4"D.
This is my first equalizer and would like some ideas from anyone that has dealt with this. Thanks fellas.
EvoM Community Team
You could put it in the lower cubby (would likely have to cut the back of the cubby to get it to fit.
Or, you could slide it in between the lower cubby and the shifter panel.
Or, you could put it in the glove box or behind the dash (less than ideal since you can't tweak it easily).
