Power source and ground for WB
If i remember correctly, it should be grounded as close to the ECU as possible. I even thought about getting a ECU patch harness and pulling both power AND ground from there. Any thoughts?
The power and gnd from the ECU harness would be a good source. I am personally using the sources from my gauges which = stereo (in both my cars)
If you're looking for the shortest power and gnd in my opinion would be the battery. Block is always a nice solid gnd, seems reasonable. Ignition is another good source.
IMO, power is power and gnd is gnd, if both are solid the unit should work flawlessly, it doesn't pull alot of amps.
my$.02
for what it's worth:
"5. The BLUE and WHITE wires should all be grounded to the same ground source.
Optimally, these (and any other MTS device ground) will be soldered to the same lug, and
connected to a single point. When this isn’t possible, connect each one to a separate lug,
and attach in close proximity. Multiple lugs on the same bolt is not optimal, and can result in
unwanted signal “noise.” When possible, soldering is always better than crimping."
taken from innovatives website.
PDF FOR LC 1 MANUAL
PDF FOR LC 1 MANUAL
picco97
May 3, 2016 09:54 PM
vetboss
13
Jan 1, 2008 11:18 AM
IMPORTIMAGE
57
Dec 18, 2006 08:25 AM
