CF Trunk fitment?
CF Trunk fitment?
Au Right, so I have a ralliart carbonfiber trunk purchased from a vendor who is no longer a part of evom. The trunk fitment on the car (which was supposedly OEM specifications) is about 1/4" off. The trunk just doesnt line up if you use the holes that the stock trunk uses. Does anyone know if this will effect my car and the trunk? i cant have my DD trunk leaking in hawaii... it rains a lot here... anyone have any recommendations on what i should do?
thanks
ed
thanks
ed
thanks
ed
thanks
ed
Ralliart made a CF truck for the EVO?
Do you have pics?
My friend had a CF truck for his EVO also, and it too was off about that much. One side of the truck just stuck up a little more than the otherside and it was obvious that the truck was not matching up with the rear panels of the EVO. He just left it as is, however, my suggestion to you is to take it to a body shop. They might have the experience to make to fit right.
Do you have pics?
Do you have pics?
Do you have pics?
that was going to be my next route if no one ha a DIY solution... thanks shiftt
I had the same problem wat you do is add washers to raise the trunk latch then hammer the latch once at a time close ur trunk till it fits perfect also remove the trunk springs so it doesn't fling open
