Can stock alternator handle a ~1200w RMS system?
I'm in the process of getting all of my audio components together. For those of you that know about Elemental Designs I have and will have the following from them:
(2) 13kv.2's D4 ~300 to 450 RMS
(1) eD NINe.1 1200w RMS x 1 @ 12.5V
**note: subs will be ran @ ~800-900w RMS
(1) eD 6000v.2's componet speakers ~100w RMS
(1) eD NINe.2 100W RMS x 2 @ 12.5V
All this with an Alpine iDA x100.
So I'll be running about 1100w or 1200w if I decide to push the subs. I know the NINe.1 is overkill for these subs but I just wanted some headroom for future upgrades.
I have read of a few that haven't had any problems with 1000w RMS, so I'm thinking I may be somewhat okay with the power I'll be using. I also would like to know of anyone who has performed the Big Three upgrade (0-4awg wire from battery (+) to alt (+), battery (-) to chassis (-), and engine to chassis (-)).
On a side note I would highly reccomend Elemental Designs to anyone who wants high quality audio components without giving an arm and a leg.
A true 1000w rms will dim every light in your car when the bass hits on any music! My system was 943W RMS and at night I couldn't play it halfway the dimming was so noticable. During the day it wasn't so bad, but voltage would drop to 11.75v at times.
Good luck there are formulas for this online if you search for them. Upgrade your alternator and you will be fine.
NINe.1 = Max Current Draw 130 Amps @ 64% efficient
So 14v x 100amps =1400watts
1400watts x .64 (efficienty) =896 watts
12v x 120amps =1400 watts
1400watts x .64(efficienty) = 896 watts
So you will be drawing 100amps to 130amps on a heavy bass notes
Evo's Alt's are around 80-90 amp out put (IIRC).
FYI , for years I ran +6000 watts system in my S-10 with the stock 100amp ALT...........
and 4 yellow tops . The way I looked at it was , the Amp's got juice from the Batts and the ALT recharged the Batts on down time .
FYI , for years I ran +6000 watts system in my S-10 with the stock 100amp ALT...........and 4 yellow tops . The way I looked at it was , the Amp's got juice from the Batts and the ALT recharged the Batts on down time .
What if I were to keep the rms power at under 700w? Would this be more in line with what the alternator can handle?
High output Alt is going to run alot of $300 plus if you can find any .
BTW 90 amps output on stock , linky...
https://www.evolutionm.net/forums/sa...volutions.html
Some thoughts...
Our car rattle with out a big system , imagine it with 2 good 12's and 1kw...
(1 10'' kicker L5 and 150w make my dash rattle to much for my taste)
If I really wanted to do a bigger system , I would skip a H.O. Alt .
Run 4ga + from front batt to trunk , add a gell cell batt in trunk , fuse BOTH batts 18" or less from each Batt + , ground rear batt . F capators , F a Alt .
Weight (LBS)
Do you really want 150lbs extra riding around in your trunk ?
Space in trunk ..
For the 2 12's sealed your box should be about 14''x28"x17" (1.3-1.4 cuft per sub)
OR for a proted box 14"x32"x22" (about 2cuft per sub)
If your do make a ported box and face it to the rear of the car (corner loading for a db gain) it might very well be to big and trap the sound in the trunk not letting it get to the cabin .....
I think the simplest/cost effective/wieght effictive way would be ....
A good Batt under the hood
500-700watts of power
1 12'' sub
and a high amp/speakers
Some thoughts...
Weight (LBS)
Space in trunk ..
1 12'' sub
If you do get a capacitor, get the right size. I had a 1 farad on two rockford 10" running ~400W rms each on my old car and the headlights would still dim when turned up loud. I went through one alternator as well. I could sit and watch the charge gauge rise and fall with the music.
Even those HO alternators can be trouble sometimes...
You gotta pay attention to the ratings.. Most of them put out close to stock at IDLE, so when your sitting there at the light, you'll still see your headlights dimming on the guys bumper in front of you !!
A friend of mine who has this badass turbo cavalier installed an HO alternator. He actually had to go through & raise his idle a few hundred so the alternator would actually work good. His was still like stock at idle...
Some thoughts...
Weight (LBS)
Space in trunk ..
1 12'' sub
Some thoughts...
Weight (LBS)
Space in trunk ..
1 12'' sub
I figure since our alt is 90a and maybe worst case scenario the car accessories demand 40% power so:
90a x .40 = 36a available
power(amps) x volts @ idle = watts ->> 36a x 14.4 = 518w available
I'll probably just get a yellow top to go along with everything. I've been reading up on realmofexcursion.com very knowledgable audiophiles on there.
Adam Thompson
Oct 11, 2016 06:07 AM
ToddRhodes
11
Jun 12, 2013 12:12 PM
bigkcrob88
10
Feb 9, 2009 03:35 PM
Andrew LB
May 28, 2006 07:15 PM
t3t418t
May 17, 2005 09:14 AM
