Defi control unit problem
Okay when I turn on the ingition the control unit lights up, as well as my gauges but what bothers me is the light goes off after 5 seconds. My friends control unit stays lit, is there anyone that knows what the problem could be??Also everything works fine, the control unit just does not stay lit.
same issue
I am having the same issue with my control unit, and I have to keep resetting my warnings every time I get in the car or the alarm will sound due to oil pressure being lower than original gauge value
It may be the case that the Defi Control box requires constant power to maintain its memory? If that's the case, you can't have it wired to switched 12v power, it needs to be wired to constant 12v power. The way I like to do that is open up the fusebox and stick tester into each blank slot until you find one that has power even when the car is off. Then take a fuse (choose a decent one that will match the current draw of the gauges) and then solder a wire to the other end of the fuse. Then plug the fuse into the blank spot and thread the wire to the the controller box.
I hope that helps, its just my best guess!
I finally had time to rewire the gauges and found a new constant power source for the red wire and wired the illumination (white) wire up with the ignition power wire to an ignition switched power source. The control unit stays lit and the gauges don't have to be reset every time I shut the car off. The issue was that the gauges were wired up through the wiring harness of the old stock gauges so after the car was started the gauges would shut off and turn back on so I just rewired them through the stereo harness and now it works good.
FooM Anchoo
Feb 21, 2010 06:47 PM
escodotcarter
Sep 28, 2005 06:44 AM
