Front bumper bolt on fender
Old Jan 24, 2010, 04:53 PM
Samuelsan's Avatar
Exclamation Front bumper bolt on fender
So earlier this month, my bumper ripped off the fitting/bolt that is on the fender. Just seeing if I could get any suggestions on what to do now. Any other options other than welding a bolt onto the fender itself?
Old Jan 24, 2010, 05:34 PM
RalliDew's Avatar
you can lay a bit of fiber glass and then re drill the holes or if your not well with glass then a few layers of Duct tape and then put the whole in it will fix it temp till you get a new one., if the tab is broken then the fiberglass way is almost a fix. id aim for that.
Old Jan 25, 2010, 09:10 PM
chaotichoax's Avatar
pictures?
the bolt is screwed in a plastic fitting...you should just have to take the bumper off and replace the plastic fitting unless you cracked that housing
zip-ties make great temporary fixes
Old Jan 28, 2010, 10:48 PM
Samuelsan's Avatar
haha yeah, I have the zip-tie mod currently going. There is no fitting anymore.. I will get a pic tomorrow if I have some time
Old Jan 31, 2010, 08:36 PM
Samuelsan's Avatar
http://s16.photobucket.com/albums/b35/Sam540/Fender/
I tried to take the best shots I could, but it was hard to get my camera under there.
Old Feb 5, 2010, 12:21 AM
Samuelsan's Avatar
Anyone?
Old Feb 9, 2010, 11:02 PM
boostin350z's Avatar
it requires us to log in as you to see the pic. just take the html code (img/src) and post that, itll post the actual pic
Old Feb 12, 2010, 01:47 AM
1SloEvoNoob's Avatar
in for pics
Old Feb 12, 2010, 07:37 PM
Samuelsan's Avatar
Old Feb 13, 2010, 06:27 AM
EvoVIII :D's Avatar
I used a zip tie for temporary but then i just got a bolt with a nut and stuck it in there, shabam!
Old Feb 13, 2010, 04:44 PM
Samuelsan's Avatar
I am usin a zip tie for now haha. Where did you put the bolt and nut? Same spot as the zip tie?
Old Feb 13, 2010, 08:00 PM
EvoVIII :D's Avatar
Yeah, same spot as where the stock screw got ripped out too
Old Feb 14, 2010, 05:06 PM
Samuelsan's Avatar
How did you (or would you) replace the missing fitting for the screw?
ps. Is the fender made out of aluminum?
Old Feb 14, 2010, 05:15 PM
EvoVIII :D's Avatar
Yeah the fender is aluminum and since mine got ripped out, i used a long enough bolt with a washer and nut on the end to clamp the bumper and fender together
Old Feb 14, 2010, 06:37 PM
ssg_petty_210's Avatar
I had this issue with my past turbo civic. what I did was it broke off so bad that i just bondo'd the corner of the bumper so that I was able to create a new drill hole. Once it dried, i made a new hole, screwed it in, and it was good as new. That is one route you could take. Its an easy job and will take less then an hour to do. Let it dry for more then an hour if you do it though. good luck
Quick Reply: Front bumper bolt on fender
