Viper 5901 Install advice Evo 8 MR
I just had this alarm installed by a guy. I have 2005 evo 8 MR
Everything works except the following:
The car remote starts in gear, in the manual it says it should not do this and I asked the installer he said he has to connect one wire to make it only start in neutral but not in gear. However, he doesn't know which wire it is? Is this correct and anyone know which wire it is so I can have this safety feature???
Also the rear defogger function is not active. Installer stated that he used up all the slots for the functions one was for clutch one was for something else? So I can't use the defogger function? ( i feel like this is kinda bs) I want to know if this makes any sense or is he just BSin b/c he doesn't know what to do with it??
If any one knows about the viper 5901 please please help me so I can get this straightened out. I paid 900 for the whole thing with smartstart I want every function to work properly if possible.
Thanks
Thanks
I don't think you can have it not start even when it's in gear because there are no electrical connections anywhere in the shift linkage like there is in an automatic. Mine starts even if it's in gear as well. I have the Viper 791XV, I'll have to check which wire is connected to the rear defroster circuit.
yea all of the functions should work, he just must not know how to hook it up. but the car WILL start in gear. like bobster said in a manual trans theres no signal given showing the vehcile is in gear. you just have to learn to not park the car in gear, if you forget you will have a mess!
U can wire it so that it only starts with the ebrake up.
Otherwise you have to install like a magnetic switch on the shifter assembly that will ground out while only being in neutral. DEI makes a pieces ive heard for this however I have never seen it. As for the defrost I think it has its own output if im not mistaken it has to be wired to a relay then tied into the defroster.
From the diagram I have..The 5 pin "RS in" harness has a 2nd "remote start status"output (-200mA output) It has to be programmed to function the defogger...meaning it needs to trip a relay. It's a blue/white wire on the viper module.
Also, the same 5 pin harness shows a black/white neutral safety (-) input. For automatics, you connect this to ground, but in manuals, you connect this to a wire that shows ground when the e-brake handle is pulled up. If you pull your armrest assembly out, you'll see a small plug for the e-brake. Meter each wire for ground when the e-brake is pulled up and attach to that wire. (I think it's a blue/red wire for ground) It can still possibly start in gear, but it's a safety so the car won't roll or go through your garage door.
Hopefully...this helps out. I don't know what you connect to for the rear defogger..or how to "program" the viper module..I'll check back to see if I can help further..
The viper 5901 has a manual transmission mode that requires you perform a sequence in order to activate the remote starter function. Seems to me like the "installer" didn't know what he was doing... Hopefully he didn't permanently bypass your clutch too. It's also in automatic transmission mode.
if your ebrake is up or not, that car is moving thru whatever is in front of it.... ask my first VIII how i know this.
My last IX i had the compustar setup which like posted before ... you are forced to go thru a sequence before you exit the car as well as if your door is opened for any reason before the remote start sequence is initiated, it cancels the remote start availability until the sequence is redone.
compustar is much easier as far as manual transmission is concerned. i have installed both in my manual transmission vehicles but I would only use the Compustar since the setup actually forces you to leave the car in neutral, the car remains running and once you exit and shut the door, the car shuts off.
As far as the defog goes, a relay does have to be setup and the unit has to be programmed as Psquared stated.
G/L
G/L
G/L
G/L
than compustar ? you must smoke crack as well.... DEI owns about what, 6 different alarm companies ? None as well known for reliability as compustar. None with the range compustar alarms have. Its the reason why you have people that say i use to have a python alarm but it sucked, so i upgraded to viper..... which is the same alarm company, same product, different box, same problem
Agreed with part A...
As for the rest, compustar has a great track record as well from my experience... I've seen quite a bit more issues with DEI, but i have always attributed that to the fact that they are used a lot more. Everyone knows Viper.
I will also have to agree with the fact that most of the issues are with installers saying stuff like i've installed 100's of those, and in reality, this is their first time and they are making phone calls to their buddies in different places asking things like are relays really necessary ?
johnjonfenomeno
177
Aug 23, 2020 08:45 PM
wjamyers
Jun 3, 2016 05:41 AM
CeeKayy
10
Feb 28, 2013 01:42 PM
