Remote door lock issue
First, I hope I put this in the correct section.
Second, I did some searching around the forums and didn't find the answer I was looking for.
Since I purchased my 03 evo 8 about a month or so ago, I've had an issue with the remote door lock fob. It seems to work on every door EXCEPT the driver's door! For example, if all doors are UNLOCKED, and I click the LOCK button, all doors except the driver's door will LOCK. If all doors are locked and I click UNLOCK, nothing happens. If JUST the driver's door is unlocked and I click UNLOCK, the other doors will unlock. The lock on the driver's door works with the key, and works with the button inside the car.
I searched and basically only found people having issues after installing turbo timers with the piece in the steering column that detects if the key is in the ignition. This doesn't appear to be the issue seeing as the fob works on the other doors and I don't have the beeping issue. I do have a turbo timer that was installed when I purchased the car though. I believe its the HKS type 1 TT. It appears to be installed correctly.
Can anyone help me out or lead me in any sort of direction to start diagnosing this issue? Thanks
does the drivers door lock work when you press the power lock button?
this website has some good tips
http://www.2carpros.com/topics/doorlock.htm
