Fuse (Wiper Sprayer) Help
So I've tried looking through the manual, I've tried looking through the fuse box under hood and under the dash and I just can't find it.
When I use my sprayer, nothing sprays. I've unhooked the tubing right where it enters the hood and it's no good either. I've had a friend hold the sprayers while I stick my head in the rear fender (when I had my carpet out for replacing) and I can't hear any sort of motor working back there either which leads me to believe it's either the fuse or the motor that's gone.
I don't know the technical term for the sprayer motor that I'm looking for or even it it has its own fuse, but I figured this is the best place to ask.
tl;dr windshield washer sprayers don't work, looking for which fuse they're on
Could be the pump, both sprayer pumps are in the trunk attached below the resivore, if the rear sprayer still works, you can troubleshoot it and swap plugs/harnesses for the front windshield pump with the rear an if it works, you could figure out if it's the pump that's out. If not, it's a fuse, I don't remember where it is but did you check both fuseboxes?
my intercooler sprayer crapped out on me and I also could not figure it out.
Hmm...I don't think I even knew we had a rear sprayer..I'll look for it and test that one.
Unless there's a secret fuse box hidden somewhere I've checked the under-hood one and under-dash one and can't find anything in them, is the wiper sprayer on the same fuse as the intercooler sprayer would be been? I think I recall running across that fuse label somewhere...
SatsuMX
Lancer Troubleshooting
Feb 22, 2016 08:38 AM
jagarcia89
Oct 4, 2014 08:42 AM
jagarcia89
Aug 20, 2014 08:39 AM
Evofletch
Jan 5, 2011 02:20 PM
