Alternator fuse keeps blowing + melted fuse holder??
like the title says.. about 2 years ago i mounted my battery to the rear trunk and so i installed a MIDI power distribution/ fuse block in place where the old positive battery terminal was
i ran the alternator, starter and 2 fuse box cables (8ga) to the output side of the distribution block and one 4 gauge power wire that ran from input all the way to the battery in the trunk
starter- 80a MIDI fuse
fuse box wire 1- 60a MIDI fuse
fuse box wire 2- 60a MIDI fuse
alternator- 80a MIDI fuse (i was told it was a 80a alternator)
it seemed to work fine for the first couple of months then i noticed that my battery light and brake light randomly came on and dash lights were dim.. so i went in and checked all my fuses from main fuse boxes (inside and engine bay) and all were fine then i lastly checked the distribution block and come to find out that the alternator fuse was blown and melted
so i replaced it with a even bigger 100a MIDI fuse and drove the car around and it help up for what has been a couple of months
...well yesterday the battery light and brake light popped on again and THIS time it melted all the fuses under there in the distribution block...i knew nothing was grounded out or else it would have blown right a away or a couple miles down the road but i double checked all the cables to make sure nothing is grounded out.. all checked out fine
replaced the whole distribution block with a AGU style fuse holder block
this time it popped after driving it a 10 miles home
any ideas on what it could be or what to check for???
here are some pics of what happened to the block
replaced with this
replaced with this
I would look into the type of wire that you were using, to the alternator and then to thebattery itself..
also the little fuse on the link that attaches to the battery is a 100amp, so I wondering if there is something goofy in your starter circuit, or your voltage regulator in the alternator is on its way out, which could lead to blowing fuses.
Check your grounds. Looks like you may have too high of resistance. When I had issues with my 1g battery it was the ground had come slightly loose. A visual check it was good. I redid the ground and added another ground to help out.
Yup, I had the same problem too. Tightened up my connections and now it's fixed. Just wondering what a 50 dollar circuit breaker would do to solve this problem.
I also soldered several connections, but personally I think making sure all the connections were solid solved the problem.
I had this happen the other day. Was it that my fuses were just not tight enough or something else? Two of the outputs seem to have over heated, the alternator one was charred, the fuse connected to it was melted (but still functional). At this point I've removed the entire block and I am planning on getting an Evo X fusable link to replace it. What kind of blocks did you all use?
ETS Michael
ExtremeTurboSystems.com – WA
10
May 13, 2012 06:56 AM
