Headunit; no power after rewire
So I was in chaining stuff around today and noticed that the previous owner had twisted/taped all the headunit connections. I pulled the harness, snipped, stripped, and soldered everything together and then put heatshrink around it all
Go to hook it back in, whala; no power to the headunit. Lights works, hvac works, etc etc, I just get no power to the headunit
I know it's wired the same way a before because I literally did 1 at a time to make sure it went back together the same
Going from the STOCK haness, the RED wire reads 12v with the ACC on, the YELLOW wire has no reading at all
Did I miss something when wiring this all back together? I'm 99% certain it's the exact same way as it was before I pulled the harness
not to be a dick, but did you plug the power plug back in? and check the fuses. behind radio and in car.
also.. sometimes when you solder you may not get a good connection after it's soldered. i've done that before.
it sucks that our stock radio plug got cut otherwise you could probably get the aftermarket wire harness install.
I have a prebuilt harness for kenwood and it's wired to a plug that plugs into the stock harness
The in-cabin fuse box doesn't have space for a fuse (slot 13) unless there is some special fuse thats supposed to go in there
Although I just tried to turn the some light on and got nothing...car started right up though. Checke fuse 11 in the engine compartment and it's good...fuse 22 and 23 (I think those two) that are in the funky yellow holder I don't know how to get out so I can't check them
turns out it was the fuse under the hood, number 22 I think...the one that controls the radio. getting them out of the yellow "holster" they're in was a pain and i couldn't do it in the dark yesterday
surprised it hadn't blown earlier since the yellow wire on the headunit wasn't wrapped where the guy had connected the two and that much have touched frame on the way out and shorted
problem solved!
problem solved!
FS[Mid-Atlantic]: JVC Single DIN KD-R900 Headunit w/ harness
Technical10
Jun 28, 2015 03:08 PM
blonde
Nov 23, 2010 05:05 AM
tetsuo12333
Mar 8, 2010 02:33 PM
