Immobilizer problem: sometimes are won't start WITH programed key
Old Apr 28, 2012, 09:39 AM
shadovarian's Avatar
I had my key programed last year in March and drove the car until November with no issues. In November I locked it away in a garage and when I pulled it out in February it has been having intermittent Immobilizer problems.
Sometimes I will go to start the car and the little green key light flashes on the cluster indicating I am not using the programmed key (when I obviously am). The car won't start until I let it sit for 30 seconds with the key out.
It is frustrating. Does anyone know what could be causing this issue? I would rather fix it than send my ecu off to have the Immobilizer removed.
Old Apr 30, 2012, 09:50 PM
Bump for answers
Old May 1, 2012, 08:31 AM
blowngasket's Avatar
Two things, the magnet inside of the ignition tumbler or the Copper Sensor. They are both Part of the ignition lock, Id check the wires first off. Other then that you might need to replace the lock again and have the key reprogrammed if you so wish to keep the immobilzer.
The way it works is the key goes into the tumbler which has a magnet that fits around a finly strained copper pickup coil thats wound onto that plastic ring. once it picks up the signal it sends it to the ECU and it says ok to go. The copper on the Plastic rings is about as thin as a human hair, also it is very tempramental, if messed with.
ScubaStevo
Oct 13, 2016 02:36 PM
Evo_Goodness
Aug 3, 2016 04:20 PM
fafaforza
Apr 20, 2016 04:17 PM
Macks
Outlander Sport
Jan 22, 2016 04:33 PM
EVOMIZ
Nov 27, 2011 05:33 PM
Quick Reply: Immobilizer problem: sometimes are won't start WITH programed key
