Radio question on a 2005 evo
Hello there I just bought a 2005 evo 8 ..I beleive it has the SSL package cause it has a sunroof black leather and under the drivers seat should be an amp but there isn't one and no radio ..Can i put in a radio from a 03-04 -05 evo non SSL package or I have to fine a SSL package radio with the stock amp..thx
On the SSL, the wiring from the speakers goes under the driver's seat, not the dash, so you would have to figure something else out with that. The radio harness is the same between both radios, so it will turn on, but that's it.
Hey thanks ..I think i'm just going to go with a after market cd player..I need a Wiring Harness Cable ..Think this will fit the SSL stock factory car harness ?
http://www.ebay.com/itm/Radio-Stereo...5256ab&vxp=mtr
I just got a stock radio and amp for a 2005 SSL.. Do I have to hook up this 6 pin round connector from the radio to amp?..I dont see this 6 pin cable in the car ..If its not there can I buy one some where..thx
Hey thanks but I dont think it's going to help ..I think I need the
METRA 70-7002 DODGE/MITSUBISHI 1992-2005 AMP BYPASS WIRING HARNESS..link below
I think this harness will plug in the harness under the drivers seat and the wires go where the radio is located so you can run a after market radio ..Seems like a pita to go after market on the SSL evo
http://www.ebay.com/itm/METRA-70-700...item231f4ce051
Hey I'm bringin this back ..I have did a bunch of research but no answer..I have a 2005 SSL package which had the factory amp..I bought the car with out a radio or amp so i'm going to install a after market radio and no factory amp ..all the speaker wires are under the drivers seat and not in back of the radio like most cars ...can I use the METRA 70-7002 ..thanks
henry22
Jul 1, 2014 09:23 PM
waylonmunoz2005
Aug 23, 2012 10:06 PM
