Alternator problems please help!!!!!
So I have a 03 evo I Took the motor out to do a rebuild do to a sun rod bearing alternator was working perfect put motor back in car alternator took a crap, went and got a new one and it will not charge the battery seems like it's not getting a power signal I did take it out and had it tested and it's good has anyone had this issue before? Thanks for the help
Agree with Fuse blown or crusty wire problem, and check to make sure the connector is not all corroded and the male side has straight prongs not bent over or broken, it happens. lol
wiseguy9
12
Jun 21, 2015 11:59 AM
