RS flickering voltmeter
I have had a 05 RS since new. Other than changing a clutch, tires, and a starter, it has not given me problems. The voltmeter has always read dead steady. In the last three months I noticed that the voltmeter would flicker (It's not the rain gremlin as there has been no rain). It seems to be related to the radiator cooling fan. As similar problem can be found on the Ralliart page:
https://www.evolutionm.net/forums/04...-flickers.html
Has the cooling fan control module been a problem on the Evos as well?
I have checked the alternator and the battery and they are not the problem. If it is the control module, it's easy to replace. Please let me know. Thanks.
Well there's good news and bad. The good news is that it is not the cooling fan control module (CFCM). The bad news is that it is the ECM. My brother-in-law (electrical engineer) and I followed the testing procedures in the Mitsubishi Service Manual in order to make this discovery.
Before I put good money down, does anybody have a link or two for testing the CFCM further? I searched but did not come up with anything.
Thanks for your help.
Interesting, on the off chance that the problem was caused by the Cooling Fan Control Module, I traded it out. As a result the flickering has stopped. It tells me that the service manual is not always correct in determining a fault.
