JDM headlights
JDM headlights
How you doing guys i finally got some MR JDM Headlights For my EVO 9 RS and i need some help on my set them up. I have to keep my harness from my original set prior on my vehicule to get my low and high beam to work ( different Headlights barbes) I upgrade my high and low beam from non-HID to HID But now i have a concern Is That i want to get my Fog lights to work But i am not familier on What to get to start and finish this work. Any help i will appreciate.
Your question is very hard to understand. I will try to give some advice. Ok you bought a set of JDM headlights and you converted your NON-HID harness to HID correct? Now you want to connect the fog light?
Well they do sell some fog light connectors that you can use. That's what I have on my car. What I did though was completely change the headlight harness from NON-HID to HID. I will have to look at my setup tomorrow to let you know exactly how I set mine up. I also purchased the fog light button but I am not sure if that's entirely necessary. I will post more tomorrow.
Here.
It's the second thread down in the "How-To" section. Wasn't rocket science to find it.
https://www.evolutionm.net/forums/ev...tch-works.html
How you doing guys I am still looking for help for this change over. Anyone that have a GSR or RS and decide to put MR headlight harness with the fuse box instead. And how difficult. I been looking for weeks and no help. Thanks
Yes I saw it but I want pictures of the process. And I want to do something more OEM thing like changing all the harness to MR but I don't see any post doing this swap. I want to see if somebody did this before
If you need pictures to understand what's going on this whole process is going to be extremely difficult for you. You should understand wiring and reading a wiring diagram.
This isn't some "swap a sub-harness and call it good". You'd need a full harness if you don't want to do any wiring work.
EvokidIX
Mar 2, 2013 05:07 PM
mot
Aug 9, 2011 10:20 AM
drifthobo
Aug 3, 2011 07:33 PM
kyoo
Sep 10, 2010 10:43 PM
alby988
Oct 10, 2008 08:25 AM
