rough idle buschr stg4 br 440
I have buschur stg4 with the BR 440 kit. Exedy twin plate
Car idles like crap. I think it is either the BOV that buschur supplies with the UICP or the cone filter from buschur. Does anybody have any experience with replacing either one of these and getting a better idle? Any help would be great.
THnx
Danny
THnx
Danny
Also wanted to add that it isnt just a rough idle due to the cams and what not. The rpms will drop every time at idle and go back up and keep on doing that until I take off. It goes down to usually 400 but sometimes almost dies.
Sounds like intercooler piping leak.Redo all your pipes with tbar clamps.I had the same problem until i re did the pipes.
3deep. I am one step ahead of you. I just ordered some tbar clmaps yesterday and they should be here in a couple of days. Hopefully that will fix it as a couple of the cheezy gear clamps get loose every week.
Originally Posted by gofaster87
Im thinking its a vacuum or fuel issue. The vacuum is easy to check but the fuel issue is tuning related.
Also if you are running BR stage 4, you are making considerable more power. Very easy to blow a vaccum hose. Or might want to find out if they plugged a useless nipple after any mods. they may have popped off as well.
David Buschur
18
Jan 6, 2009 10:19 PM
Thunder-rush
May 22, 2005 08:04 AM
black evil evo
13
Dec 3, 2004 11:34 AM
