All about CAMS....
You have to be joking you couldn't find this anywhere. 264's are about power throughout the entire RPM band and 272's are for more power up top. You can make more power using 272's, but it would mostly be for drag strip car making some serious power. I'm sure there is more to it.
Have fun trying to get an answer, everyone has a different opinnion on cams. Trust me i hve tried to make up my mind, come to find out i bought all 4 . Let me see i have 264I,264E,272I, & 272E.
272i for your 264i.
pisses me off when ***ers dont even try to search (especially newBs)
Edit: I was pretty drunk when I made this statement and dont really remember it
Difference in them are the duration. One is a 264 and one is a 272 duration. This is how long the valves stay open. Besides that they are the exact same. You will get more top end with the 272's but you will get more torque with the 264's. You also have to remember though that the more duration is not always the best. You start to get overlap which will make you actually lose HP. So its better to get a good combination of duration and lift. More lift will actuall give you the same effect without causing overlap. The lift is how much the valves open letting more air in and out but you can have a lower duration and still get the same effect since more air will go in due to them being open wider. Anyway HKS dont give you a option in lift so im just talking out of my a$$ now.
Chris
Chris
Chris
Chris
Chris
Chris
HKS 264 :
Duration of 264 deg
Duration of 206 deg @ 1mm
Lift of 10.8mm intake / 10.2mm exhaust
HKS 272 :
Duration of 272 deg
Duration of 214 deg @ 1mm
Difference is higher duration between the cams
Duration of 264 deg
HKS 272 :
Duration of 272 deg
thanks to the view people with answers, i appreciate it. to you other jackasses who would rather pretend like they know the answer, and say search, than to actually give it to me......you all suck.
have you ever tried to do a search on here? if i type in cams, the first 100 threads that come up are where people are listing their mods and talking about getting cams and all that ****. NONE OF THAT ANSWERED MY QUESTION.
and id be willing to bet i know more about modding an engine than any of you assclowns that called me a noob or told me to search. can't have good informative discussions on this forum because dip****s like yourselves wanna throw your useless .02 in.
again, thank you to the intellegent people who answered my question.
Originally Posted by mayhem
Duration?...How long they're open? ...what's the units for 264/272? What does that number actually mean? A lot of talk and smack around here but little tech to back it up.
Duration = Duration refers to how long a valve is opened in relation to crankshaft rotation. This open valve time period is expressed in degrees of crankshaft rotation. So, a cam specification of 220 degrees duration simply means the cam holds the valve open for 22 0 degrees of crankshaft rotation.
Lift = While duration refers to how long the valve is opened, cam lift is used to determine how wide the valve is opened.
If the valves are not opened wide enough, they will cause a restriction for the air trying to enter or exit the cylinder. However, opening the valve past a certain point will not increase the flow to (or from) the cylinder.
Seperation = Separation refers to the spacing between the intake lobe and exhaust lobe on the cam shaft. This spacing (or separation) is expressed in degrees on the cam, not on the crankshaft. So, a 108 lobe separation means the intake and exhaust lobes are 108 degrees apart from each other on the cam shaft.
This spec by itself really doesn't mean anything. If you hear someone else is using a cam with 108 separation, don't think that you should use cams that only have 108 separation!
Separation, just like centerline, is another way to tie the duration to the crankshaft rotation and end up with valve events. This spec is a little more complicated though, because it is in cam shaft degrees and the crankshaft rotates two degrees for each one degree of cam rotation. Also, if the cam has been installed either advanced or retarded, the valve events will be different.
Centerline = The cam's centerline specification is used to tie the valve timing to the crankshaft's rotation. This spec is expressed as the number of degrees the crankshaft must rotate from top dead center until the cam has rotated to the peak (or centerline) of the lobe.
The centerline spec and the duration spec can be used to calculate when the valves open and close in relation to the crankshaft's rotation. When the valves open (or close) relative to the crankshaft's rotation is known as valve events or valve timing. Some cam manufacturers will provide valve event information and others only provide duration and centerline information
MAYBE YOU WANTED SPECS ON THE CAMS??
HKS 264:
Duration of 264 deg
Stock valve springs OK
HKS 272:
Duration of 272 deg
JUN 264:
Duration of 264 deg
Duration of ___ deg @ 1mm
Lift of 10.5mm
Upgraded valve springs required
JUN 272:
Duration of 272 deg
Duration of 235 deg @ 1mm
Lift of 10.8mm
Tomei Poncam:
Duration of 260 deg
Lift of 10.7mm intake / 10.2mm exhaust
Tomei Procam:
Duration of 260 deg
Lift of 11.5mm
Piper Ultimate Road cams:
Duration of 265 deg
Duration of 217 deg intake / 211 deg exhaust @ 1mm
Lift of 11.5mm intake / 10.8mm exhaust
Piper Rally cams:
Duration of 265 deg
Duration of 217 deg @ 1mm
Lift of 11.5mm
Piper Race cams:
Duration of 272 deg
Duration of 224 deg @ 1mm
Lift of 12.0mm
PEOPLE LIKE YOU **** ME OFF!!!!
Chris
gotta love it when people act like as*es over someone asking a simple question. GSUJEFF55 does have a good point about the search option. i tried doin search on cams as well as other things. most of the time u end up wit no info at all, except for what people have installed in there cars. hopefully the mods will clean up the forums soon.
ya really act like its that hard to answer someones question without giving an attitude. if u get mad over a repeated question then dont reply to it. it may be repeated to you but not to the person asking it.
this has been a rant, now we return u back to your topic.
by the way thats for the info on the cam lift and duration too. even though i still dont understand.
