Just installed Greddy FMIC
Old Oct 18, 2004 | 07:31 AM
chapter8's Avatar
Thumbs up Just installed Greddy FMIC
All I can say is wow, I got this intercooler installed over the weekend and the spool up time is so much faster. It hits full boost so violently now and I hit full boost 21psi @ 2700 rpm. I was hitting this at a little over 3000 rpm before. The sound of the turbo is amazing as well sound like a big sinlgle turbo now
I was under the impression that I was going to get more lag due to the larger unit but thats not the case.......also I gained 2psi of boost after installing it and had to lower the boost. So the pressure drop is alot better with the unit as well. I got it from www.AMStuning.com for $750. It includes the intercooler and the lower pipes. The only pipe that is not replaced is the one from the Throttle body to the first rubber elbow. However greddy has also released this pipe as well and will be picking it up.
Very satisfied with the product
Old Oct 18, 2004 | 07:34 AM
chapter8's Avatar
btw mods to my car are turboback, intake, fuel pump, flash, mbc and this intercooler
Old Oct 18, 2004 | 07:42 AM
Az3ar's Avatar
very nice. any dyno runs? I am looking for an IC because I am heat soaking my stock one badly. any fitment issues? what about the undertray? any pics?
Thanks
Old Oct 18, 2004 | 08:19 AM
sleet's Avatar
Very good to hear, I am also looking for an upgraded IC...perhaps I will look towards this one. There are sooo many to choose from.
Old Oct 18, 2004 | 08:21 AM
Az3ar's Avatar
I am lost between these IC
AMS
Greddy
Injen
Old Oct 18, 2004 | 10:29 AM
chapter8's Avatar
AMS
Greddy
Injen
If you are upgrading the turbo I think the AMS would be better but the unit is alot more then the greddy if you include the pipes
Thanks
No fitment issues, no cutting, undertray is intact
Old Oct 18, 2004 | 10:37 AM
Az3ar's Avatar
I do have an aftermarket turbo 3071
Old Oct 18, 2004 | 10:40 AM
sleet's Avatar
Got any pictures of this FMIC installed?
Old Oct 18, 2004 | 10:42 AM
Guack007's Avatar
Is this the V spec or R spec greddy?
When you say you hit full boost by 2700, what gear are you in and at what rpm did you floor it at?
Old Oct 18, 2004 | 10:56 AM
chapter8's Avatar
I will post some tommorow
V spec
3rd gear wot started at 1500rpm
Old Oct 18, 2004 | 10:58 AM
Geo@EvoStore's Avatar
That is pretty sick spoolup.
Old Oct 18, 2004 | 12:09 PM
Guack007's Avatar
Ill see what kind of spool im making in 3rd from 1500 on my lunch. thnx for the info, perhaps this will be the upgrade for me
Will you share your mod list and tuning please (ie.what kind of turboback, fuel, what intake,etc)?
Old Oct 18, 2004 | 12:17 PM
chapter8's Avatar
Here is all I have as far as motor set up is concerned
hks rs intake
greddy bov
fuel pump
helix cat delete and exhaust (freakin loud!!!)
Espelir Downpipe 3"
Dynoflash
Halmann MBC
Greddy Spec V core
Greddy I/C hardpipes
Old Oct 18, 2004 | 12:22 PM
Guack007's Avatar
thnx bro
Old Oct 18, 2004 | 12:30 PM
marksae's Avatar
I love the cast end tanks of the greddy intercooler. The transitions are much smoother compared to the stock end tanks. That spool up sounds sweet.
RRE has pics of an install on their website:
http://www.roadraceengineering.com/e...ntercooler.htm
