TurboTrix tunes a 550 whp Weightless White in Tampa!!!
Originally Posted by Geo@EvoStore
That kind of power on that dyno is pretty sick considering it reads pretty low.
This doesn't really matter, so long as one compares numbers from comparable dynos.
Originally Posted by Ted B
Actually, these numbers should not be 'conservative' readings. FWIW, a Dynojet does not give conservative readings, and if a Dynapak gives comparable numbers, it is not a 'low reading' dyno. A Dyno Dyanmics dyno is a conservative reading dyno.
So conservative or low makes no difference to me.
Are you the person that was up here a couple weeks ago with a silver STI and you raced a few people?
Nice numbers.
It does sounds like the Miami EVO that raced a stk turbo'd EVO in Orlando. I understand the Miami EVo lost too.
Still great power.
BTW Geo, I posted on the flash thread that CFT's AWD dyno was operational, but maybe it was too late cause they never responded to the post.
Aerocomp dynos came in this past weekend they where installing it. The other is centralfloridaturbo.com 5 minutes from our shop.
Originally Posted by v8killer
Sweet, thanks for chiming in. You defiantely have one of the most powerful Evo 8's in the US!!! Congrats!!! Did you drive it or trailer it?
Originally Posted by jj_008
Can you post dyno sheets. How is the lag? At what RPM in 3rd gear do you reach 20 psi?
Thanks
Thanks
Mark going to fax it to me .
Originally Posted by Fourdoor
Hmmm, says $2850 depending on what all is included that is a great price!
What all did you get for your money?
Later,
Keith
Later,
Keith
Turbo td06sh-25g and type-r 52mm. wastegate .
all oil line and fitting .
i'm spend $4000 that include part and labor installation and upper intercooller piping .
Originally Posted by wave65
set up is
workspower full turbo kit (http://www.workspower.net/evo8turbokit.html)
tomei cam 11.5 lift
tomei cam gear
AEM plus all bolt on things
Mark said i made 470-480 on 93 octane . (24psi)
on race gas mix made 550hp (29psi) only second pull then jumping timing (valve bend).
tomei cam 11.5 lift
tomei cam gear
Very interested in hearing the cause so noone else repeats it.
