My antilag system
Old Nov 22, 2002, 07:20 AM
JF15's Avatar
Talking My antilag system
I am lookng for a way to activate my antilag system on my evo 4. please help me
Old Nov 22, 2002, 09:30 AM
Lan Evo's Avatar
If my memory serves me right, there is no ALS on the stock EVO. (If you mean the "bang-bang" anti-lag system) However, one of the feature that reduce turbo lag is the twin-scroll turbo...which divided the exhaust gas in two channels going to the exhaust turbine, which reduce the lag during the throttle is lifted.
Old Nov 22, 2002, 04:08 PM
JF15's Avatar
Hi lan evo, i did read a couple of article regarding the factory build ALS onto an Evo 4. And it is disable for the road version but there is a way to activate it as well. Anyway, thanks for your information. i appreciate it
Old Nov 22, 2002, 04:50 PM
ishi's Avatar
Anti-lag??
We don't have a anti-lag system(we might be calling it something different) Can you give a more detail description as to what this system is and does (other than obvious) then I take look around here(JAPAN) and see if I can locate one PEACE
Old Nov 22, 2002, 05:57 PM
TearItUpSports's Avatar
Anti-lag could also be called a stutter-box. Basically it would open and close the throttle plate real fast to fake a load on the engine, which in turn, builds boost even while the clutch is in, so you can take off already at like 4-5 lbs of pressure.
Another way to do it, and likely how the EVO would, is the ECU can pull timing to simulate a load condition on the engine. Basically you need to be able to unlock the program in the ECU.
Old Nov 22, 2002, 06:13 PM
ratboy128's Avatar
could you add one of these antilag systems to the rrm turbo kit for the us lancer? or program it into a programmable ecu, like the aem one or something?
Old Nov 22, 2002, 06:58 PM
ishi's Avatar
Originally posted by TearItUpSports
Another way to do it, is the ECU can pull timing to simulate a load condition on the engine. Basically you need to be able to unlock the program in the ECU.
Sounds like the misfire systems present in Rally car? Is it the samething??
Old Nov 24, 2002, 06:04 AM
JF15's Avatar
thanks for all the info, so where can i get to unlock the program?
Old Nov 24, 2002, 06:37 AM
evocrazy's Avatar
Sory guys this is way off topic but, ishi where in Oki are you? Thats where I am! We should get together sometime and go to the races. PM me
Old Nov 26, 2002, 03:06 AM
JF15's Avatar
Hi claudius, i knew a guy who doing those rally on mitsubishi car. He told me that the antilag will introduce if we rev higher then 5000rpm and hold for at least 3 second. Besides that, i read few article which said that the antilag system is not activated in the factory ecu. so which mean, i am confused!!!!
Old Nov 26, 2002, 03:00 PM
4banger's Avatar
if you have lots of $$$ then get anti-lag because you'll be replacing you turbo all the time. turbo running 7psi on idle rev's strains your turbo like you wouldnt believe but hey it's fun let me tell you. the Motech M8 is what you want.
Old Dec 2, 2002, 03:34 AM
JF15's Avatar
Motec.....too expensive!
Old Dec 4, 2002, 08:58 PM
strangezz's Avatar
The Autronics can arguably do the same job as as well as a Motec...and since you are in Melbourne, there sure won't be a problem finding a tuner familiar with the Autronics.
Quick Reply: My antilag system
