ATP 3037 turbo kit Dyno results
430whp and 360 wtq
MODS:
ATP 3037 turbo kit
Revolver cams
25psi
100 octane
Greddy R Spec FMIC
660 Greddy injectors
3 Injen exhaust
DynoFlash with super afc 2
i will post dyno sheet later
MODS:
ATP 3037 turbo kit
Revolver cams
25psi
100 octane
Greddy R Spec FMIC
3 Injen exhaust
Originally Posted by evo8r
430whp and 360 wtq
MODS:
ATP 3037 turbo kit
Revolver cams
25psi
100 octane
Greddy R Spec FMIC
3 Injen exhaust
MODS:
ATP 3037 turbo kit
Revolver cams
25psi
100 octane
Greddy R Spec FMIC
3 Injen exhaust
those Revolver cams are on my list. either piper or revolver they just work the best with these turbos. great numbers man.
The factory cams will pull to 8k rpm if adjusted to do so and with sufficient boost at higher rpm. My guess is the actual duration (e.g. @1mm) of the Revolver cams is shorter than an HKS 264 set, but the lift is a bit higher.
There may be another 20hp in there with tweaking unless that proves to be the limit for the ATP version. If you would, please post the A/F data when you post the dyno sheets.
Originally Posted by Az3ar
ya I have been hearing nothing but amazing things about them... do you have the springs too?? what cam gears do you have??
Originally Posted by Turboholic
nice number on GT3037 serious turbo,
what number did you get on pump gas?
let's see the dyno sheet.
