View Poll Results: Have you removed the clutch restrictor?
Yes
33
36.26%
No
58
63.74%
Voters: 91. You may not vote on this poll
Clutch Restrictor Removal
i put the ss line in tonight and it feels much better, so i will get use to it, then i will take the restrictor out later. i'm a good driver when it comes to clutches, thats all i have ever had, but my EVO is the first AWD that i've owned. still want more tips if people have it. dont want to mess my car up!!
I had a SS line in with the restrictor, and now without. With the restrictor and the SS line, shifts were still slow because engagement and disengagement delay. The SS line helped a little, but removing the restrictor made the biggest difference. I did have to readjust my clutch pedal after removing the restrictor, so that probably contributed to the improved shift quality on my car.
Has anyone reinstalled the restrictor after pulling it? It's part of the slave isn't it, so I guess it wouldn't be too expensive to just put in a new slave if you changed your mind.
The clutch restrictor should be included when you buy a new slave cylinder. It was on my GSX. Why would you want to reinstall it? Has anyone tried boring one out before? That might be a good compromise for people who want quicker release, but some restriction.
I have not removed it, basically because my tuner (Dyno4mance) advised against it. Now, that said, I bought the car used and it has a braided stainless clutch line and the previous guy could have removed it...but I think it's still there. the clutch is a little "floaty" if that makes any sense. I do not have the "positive engagement feel" that people talk about who have removed the restrictor.
Originally Posted by EVO8LTW
I definitely don't want it for the stock clutch and street driving, but if I were to ever get a heavy duty clutch (like an Exedy twin) and get into 1/4 mile racing, I'd like to have my tranny safety device reinstalled
i just got my evo 2 weeks ago, i had a audi 4wd with a inline 5 turbo in europe, I never heard of anything like a clutch restrictor till i got to this thread. my audi shifted so much better and the clutch was 10 times better. tride to lounch the evo and it sucked plus the clutch stunck. It was 3k rpm lounch withvery litle slipping but when i got off the clutch it felt like it still slipped. that is what made me look for answers.
pls tell me how to remove the restrictor. I am new to mitsubishi but I done 2 honda swaps 10 tranny installs and a lsd install. So I think I can handle it
ths
excuse my English but I am Romanian I am in the Us temporary
ths
i took mine out, and at the same time added a stainless line. the clutch feels totally different, not as vauge anymore, if your not a stupid *** droppin the clutch take the restrictor out.
Friday around 5 pm started on taking the restrictor out and replaceing the line with a braided one. all went ok till i got to the point of threading the bajo bolt on the master cylinder. it took 45 min of taking turns with a friend to get it donne.
Clutch is a lot better dose not smell as bad when I do my 3-4k litle slip lounch.
peddal has inproved in feeling
and shifting is better.
Ths for the help guys, the directions wore grate
yes.
because i did not want increased wear on my new clutch
cusco twin plate. i burnt the stock clutch pretty fast because i was slipping alot while the restrictor was slipping for me.
