Topspeed PRO-1 SS manifold install
Is this the same header that evo8.com is selling? the PRO-1 EVO 8 Turbo Manifold with the anti lag ports? I am curious if I could use one of those ports for my egt gauge?
Originally Posted by xy2nickx
Is this the same header that Evo8.com is selling? the PRO-1 EVO 8 Turbo Manifold with the anti lag ports? I am curious if I could use one of those ports for my EGT gauge?
To install an EGT properly on one of these tubular manifolds, you would need a very competent welder to add a bung. Even then, you would add the possibility of cracking down the road at the site it is installed.
