Kaaz LSD
Kaaz LSD
Hi,
So im going to be installing a Rear Kaaz LSD and was wondering if any one had some helpful hints? Any thing is appriciated. Any Write Up's? Im pretty sure i got to drop the rear axels, is this correct (there arent any bolts to disconnect from diffi)?
Thanks You!
Thanks You!
Well, you will have to remove the rear axles and drive shaft. The most important question is are you familar with adjusting the gears after replacing LSD? If you have never done it before get someone with experience to assist as you or can damage the crown and pinion gears and end up with a very noisy and expensive tramsmission repair. I have done many transmissions and diffs in different cars and at the moment I am rebuilding a Subura WRX Transmission with comp gears after the stock gears exploded.
vikingboy
15
Jun 27, 2008 03:26 PM
