Ordered my turbo kit
Location: driving the 10 second beast in ohio or running lightmods.net
i had absolutely none....i am speaking from experience. I ran 10 11.5's at 122+mph with it. THat was at only 25psi , stock intake manifold, throttle body, maf, ecu (with pump gas flash).
https://www.evolutionm.net/forums/sh...d.php?t=105552
no surge whatsoever. Thats the point of the anti-surgering inside the intake side of the turbo. It prevents surge as far as i know.
Originally Posted by mattbcool
what is spool up like?what rpm? dyno #'s?
Originally Posted by 1StockEvo
What upper ic pipe you running and clutch? Did you also upgrade your fuel system?
Originally Posted by bo0oost
What exhaust manifold did you use? What was your spool time like?
Dave
just a question. But on the ATP kit or any 3037s turbo, looks like they have a 4" compressor inlet, does the kit come with a stepdown hose so you can run normal sized piping for us who have to use intake pipes with the stock MAF?
bump.
