RPM rises then drops back HELP
hey guys, i've got a concern.
one of my friends just got an MR about a month ago. It was driving fine but now when in any gear in full throttle the rpm jumps up and then back down.
example.... I'm in forth gear low rpm, i floor it, when the rpm hits about 3500 the rpm just suddenly jumps to 5500 then back down to 3500 and then feels normal. This happens in every gear but first is not noticable.
If i am at partial throttle the car feels normal all the way to redline.
The car is completely stock by the way.
He must have done some serious launches. It looks like the clutch is slipping due to high temp glazing or the clutch is gone.
But, I believe he glazed the clutch so just drive it normal for awhile and it should get better.
No.
The reason why clutch slips in 5th gear or any higher gears is due to engine torque. When you floor it the engine wants to spin but you're in a higher gear which requires more power to drive the gear. But since your clutch is weak, it spins instead. If you are using lower gear at higher speed, it doesn't require lot of torque to drive gears.
xkpbreaker
Apr 28, 2005 09:37 AM
