Greddy Type-S Lower Vacuum Port Connection...
The lower port is not a vacuum port...it is meant to be connected to a pressure source.
That being said, you should try to connect it as close the the intake manifold as possible, but still pre-throttle body (or you will have vacuum when off throttle). You want the pressure going to that bottom nipple as close to the pressure in the intake manifold as possible, otherwise the BOV may not hold boost very well and open early.
Eric
Eric
here try the single spring mod
read thru settings and enjoy
http://www.evomoto.com/tech_info.php?tPath=1&tech_id=7
i did the single spring mod and the guy at a local shop told me to put it back in cause it was opeing with the single spring. he took it apart and said something little was wrong and he ordered a part (the bov is not 2 months old) im going back next week for him to fix it. But im still courious bout the little port should i t off a vac. line to the small port also. But thanks Chinto for the website all look over it agian and take another swing at it!
no prob.. i have the type s installed with out the lower port connected and haveing little to no issues only when low rpm and high gear and slow throtle release i get a flutter other then that it works great.
and the lower port is spost to have preasure not vacume.. o well.. good luck.
though its not ideal (i plan on moving it to the Upper intercooler pipe by the throttle body) i have mine tapped into the vac line port on the turbo's compressor housing (Boost Control Input)
no flutter, no surge.... works flawlessly
if you use the anti surge port you MUST use both springs
i did the single spring mod, but I realized that if I blow air into the top port, there is air leaking from the small lower port. I am thinking if it's the way it supposed to be, or it's my BOV is leaky and I might want to plug the small lower port so it doesn't leak at boost (or lose vacuum at idle)?
Originally Posted by BJai02
i did the single spring mod, but I realized that if I blow air into the top port, there is air leaking from the lower port. I am thinking if it's the way it supposed to be, os it's my BOV is leaky and I might want to plug the lower port so it doesn't leak at boost (or lose vacuum at idle)?
i was told you are suppost to plug the small port or have it on a return.
So let me ask where ist eh best place to grab the positive pressure from the manifold. I thought a vacum source turned into positive pressure when you go into boost am I wrong?
fostytou
338
Nov 10, 2023 11:55 AM
