Manual Boost Controller
I have read quite a few posts regaurding this subject and the question I have is can you hook up a MBC to the exisiting lines that run from the stock boost solenoid. Is there a difference and if so what is it, and why does do it the why they currently do. Any help on this subject would help I would like to know so that I could get my install done correctly. Thanks
u can..if you want...i rather use a larger diameter hose if i were you...i think the stock hose is just kinda small....if you were to use the stock ones..make sure u take out the pills in em and reroute the hoses...
better way would be just to disconnect the stock set-up, leaving the stock one plug in(for the cel light) then run the vacuum source from the turbo hosingw. new hoses...
