What is wrong with my EVO? HELP!!
Ok, I don't know if anyone remembers but I posted a previous thread that my EVO shakes and makes a rumbling sound around 80 mph. It also started doing it in 3rd gear around 3000 rpms. This all started after I got a Exedy Hyper single put in. I took it back to the mechanic (who is the EVO mechanic at the local Mitsu dealer) and of course it would not make the sound. As soon as I left, when I got on the interstate it started shaking and rumbling again.
Also, for the first time, when I was in 5th gear around 70 mph, I pressed the accelerater pretty firmly and the car just violently jolted. The bov released the air pressure, I shot forward in my seat it was so sudden. It did it 2 more times on the way home. Only when I get on the gas aggressively did it do this.
Does anyone know what might be the 2 problems with car?
Originally Posted by Noize
Sounds like boost cut. Are you reflashed to correct this? The colder weather will do it; once you go over 20psi, you'll cut. Reduce boost to ~19psi and the problem will go away.
Any ideas on why my EVO is shaking and rumbling?
friend i dont know what you have installed on car.
check your tyre lugs first.
Recheck your clutch for broken springs
Check Boost, usually evos overboost after 1.3 bar(limitations to save engine)
check your wastegate.
Agree that sth is out of balance
Evo_Xela
14
Nov 16, 2016 12:16 PM
MyEvoRocksUrv8
17
May 20, 2008 02:36 PM
LancerEVOmann
10
Nov 10, 2004 10:15 AM
