evo 7 power fc to evo 8. please read.
i found a evo 7 power fc and the seller says it will work with some modifications if i install on the evo 8. ive searched everywhere and cannot find info on this. anyone know if it will work? or tried it? what is the difference?
also, what is the part number for the evo 8 edition pfc?
whats the number for the 7?
thanks.
thanks.
Honestly if they say it will work I would be sure to get somthing in writing that states if it doesn't work will they issue a refund before you throw any money down. The correct model number for the D-Jetro is the 414M908 I believe, this model is specifically mapped for the US car. Just call Apexi they will tell you for sure but there are several differences this being the reason that Aepxi remapped and issued a new model number. Vendors have been know to import the 414M008 to the US becuase the EVO 7 has the same ECU Pins and they get it for alot cheaper for a better resale.
900 is way to much used for the L-Jetro and honestly if you are keeping the MAF (L-Jetro you have too) you will be much happier with a UTEC or Xede. And you will have to do minimal tuning with better results I can promise you that.
basically im sick of the variability of the factory ecu. also, i have a turbo setup that will make 500whp.
Originally Posted by rt turbo
i doubt that. ive already found the limits of my current piggy back (emanage) i do not want the stock ecu in may car. it has way to many maps, can change them when it sees fit rendering the current tune less useful. through logs, ive seen it run leaner sometimes, and richer the other regardless of the tune. ive seen it run completely different timing curves when the temp has changed outside. the xede may be better than your regular piggy back, but it still uses stock ecu. also, with the ljetro you can run a larger maf that can read more air. i like the way maf's work. whos to say a map is better if they can both read the same amount of air?
The Xede and UTEC are far better than the emanage, or PowerFC ever thought about If you have never seen a power fc and how you tune them they are like pissing in the wind, just hope it doesn't blow back in your face.
Good day partner
94AWDcoupe
Jan 4, 2017 09:05 PM
