Helix Dp rant
Helix Dp rant
Well i tried to hang the Dp with kartboy hangers and the fit is so tight that the Dp will shift over to hit the oil pan. Has anyone else noticed this? Now I have to hunt around for the crappy stock hangers. Seems that if the Kartboy hangers were about 1/8th inch longer everything would line up perfectly.
Yeah I tried to get the kartboys to work with my helix downpipe. Really there is no way to do it. It isn't kartboys product that is the problem. It is the downpipe. I decided it is my fault for cheaping out on the dp.
Ben
Ben
Did you bolt the rest of the exhaust up to the downpipe yet? Bolting up the rest of the exhaust should help pull the downpipe back down away from the oil pan.
I have the kartboy hangers also. But I have an HK$ downpipe. They were pretty hard to put on with the exhaust bolted to the downpipe so I just took the downpipe to cat bolts off.
It worked for me. No rubbing or even come close to the oil pan.
hope this helps
Ben
Ben
Thats funny.. the kartboy hangers worked great w/ my Helix downpipe.
I have a turbo-xs downpipe and I took it off and back on 3 times and I couldn't clear any of the lower cross-bars, fit was just horrible.
Took it to the shop (Precision tuning) and when they put it on everything was perfect, I can even take some spacers out.
A buddy of mine has Helix v2, when we put his on there were no issues.
Downpipes are a ***** to put on because of the springs up front which can rotate then left/right and make it fit good or bad. It also helps when you put the rest of the exhaust on.
Good luck.
Good luck.
you probably have the ver.1 downpipe,ive talked to a couple of people that had this issue before but they were able to tweak around to make it fit.i have the ver.2 that doesnt have any issues at all and has space all around the area.
I just went to the advanced auto right by my house and got different hangers. They are actually just a little longer and have almost no play in them just like the kartboys. I have a Helix DP, perrin test pipe, Greddy Evo 2 cat back. Everything lines up perfectly.
